Screamin eagle air breather
Old Mar 27, 2014 | 08:26 AM
JaxTeller's Avatar
JaxTeller
6th Gear
Default Screamin eagle air breather
A friend of mine is offering me a free screamin eagle air breather (cone style) off of his 09 road king, my question is what will I have to modify to fit it on my 07 Heritage or will it be a direct fit?
Old Mar 27, 2014 | 08:33 AM
yzergod's Avatar
yzergod
Go to the HD website and look up the fitment for the model he has. My bet is it will not fit.
Old Mar 27, 2014 | 10:06 AM
24v's Avatar
24v
If his Road King has throttle cables it should fit. If it is Throttle by Wire, it won't.
Old Mar 27, 2014 | 10:21 AM
tmitchellof PG's Avatar
tmitchellof PG
You can change an exhaust without too much problem with the air/fuel mixture. You can also change to a better breathing filter element without a problem, but if you put a complete SE air filter on, the back plate will have a larger air inlet which will lean out your air/fuel mixture.
This means you will probably also have to add an aftermarket fuel/air adapter or at the least constantly check your plugs to make sure your not running too lean.
Tom
eglideic
13
Sep 6, 2016 04:00 AM
harley7316
Jun 10, 2014 07:13 PM
0796bob
Feb 1, 2011 09:08 PM
J-Train
Exhaust System Topics
Sep 1, 2009 09:51 AM
harleyflo
Jun 26, 2007 10:14 AM
