Headlight/Tail light- blown fuse
Old Sep 2, 2005 | 09:43 PM
supernova72's Avatar
supernova72
2nd Gear
Default Headlight/Tail light- blown fuse
This may be an old subject but I appreciate any input. My 02 Fatboy headlight and tail light fuze keeps blowing. I've head the headlight out once before doing some mods and had to cut the wires the reconnnect and I suspect there is not a short. If that isn't the case, anyone out there have the same issue? Brake light and signals work fine. No front running lamps however.
Thanks.
[IMG]local://upfiles/981/33B72AE55AD94EFFB26B74660BA84582.jpg[/IMG]
Old Sep 2, 2005 | 09:48 PM
supernova72
2nd Gear
Default RE: Headlight/Tail light- blown fuse
Sorry my spelling stinks. That would be fuse vs. fuze.
Old Sep 2, 2005 | 10:33 PM
HDF Tech's Avatar
HDF Tech
You mention that it is the tail light that keeps blowing, take a look at the harness where it passes through the rear fender from under the seat. There have been some that rubbed the harness bare from the wheel bottoming out inside the rear fender.
Old Sep 3, 2005 | 12:01 AM
Mike05's Avatar
Mike05
My 05 Heriatge Classis starting blowing lighting fuses at 2K miles. The insulation for the headlight was worn through at the fork cover. Seems the hole is a little small. I repaired the wires, split a piece of rubber tubing to slide over the wires and fastened it with small tie-wraps.
Old Sep 3, 2005 | 06:00 PM
supernova72
2nd Gear
Thanks for the great tips. I'll check them both out!
Thanks again.
misfitJason
Sep 22, 2016 10:32 AM
StlJimmy
Feb 21, 2015 10:10 PM
exec88
Jun 30, 2010 07:35 AM
stlboarder
Mar 30, 2010 07:11 PM
JerrySC
Product Reviews
Oct 14, 2006 10:59 PM
