KURYAKYN HYPERCHARGER
Old Mar 30, 2007 | 12:06 AM
Maccabi's Avatar
Maccabi
5th Gear
Default RE: KURYAKYN HYPERCHARGER
I ended up buying a PCIII off a member on this site. I never knew how much control you can have over the ECU...you can actually control each cylinder! amazing where technology has come.
Old Mar 30, 2007 | 12:28 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: jakazz
ORIGINAL: Nasty350LT1
I would not waste my money on the Hypercharger.
I have heard nothing good about them.
I have heard that they do "Nothing" for the bike.
They only look nice, big waste of money.
Go for the "Stage One" kit and save your money.
That's what I did. JMHO
I wouldnt say that was exactly true....... The only difference I see in the stage 1 ac and the hyper charger is the hyper charger looks better. They both use a k&n filter so I would say they both would flow the same air through them.
BIG NOTE though, the hypercharger butterfies will not work because the throttlebody and manifold on the 07 are one piece and you cannot get a manifold vac without drilling the manifold and installing a bung. Thats what I had to do on my 07, but I also used an ebay HC from an 05 motor.
[IMG][/IMG]
By the looks of those pipes, I would guess that your bike definitely needs some more fuel.
Old Mar 30, 2007 | 03:10 AM
vertigo14's Avatar
vertigo14
that tire has a bandaid too? heh
I dont think the SE stage 1 aircleaner is a K&N either.... I am sure of it actually I have one.
I think the K. HyperCharger looks kinda neat but they are bulky.. and uh ya whatever there are other aircleaner covers that look cool as well.
Old Mar 30, 2007 | 04:32 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL:
I don't know about now, but the older SE air filter was a K&N.
Old Mar 30, 2007 | 04:39 AM
07sophtayl's Avatar
07sophtayl
Not really in agreement with this. I have the Pro R Hypercharger. I am wrapped with the look and performance. It is a taste thing. I like it and it performs great. The limitation is definitely not the hypercharger on a stock set up. As XXX said, they use a K & N filter and the pro R has a radiused throat to improve airflow into the throttle body.
In terms of bulkyness, it is not really any bigger than the stock cleaner- just looks it because of the butterflies.
In terms of the Butterflies and vacuum- If you specify what bike the unit is going on, then you will be supplied a simple adapter unit that goes under the MAP sensor. No drilling required. I have installed 6 of these in the last 2 months. Very effective.
[IMG]local://upfiles/21019/408C4458BC3C489487CE1174C54EE0E2.jpg[/IMG]
[IMG]local://upfiles/21019/512F06EEB7104138BE6545757C864B74.jpg[/IMG]
[IMG]local://upfiles/21019/203F917A843040B09301F81E3BFFDE7A.jpg[/IMG]
Old Mar 30, 2007 | 05:06 AM
xxxflhrci's Avatar
xxxflhrci
If a Hypercharger does nothing else,it compliments a pair of pointy-toed snakeskin boots and mullet rather well.
Old Mar 30, 2007 | 05:41 AM
vertigo14's Avatar
vertigo14
well theSE1 they put on my 07 fatty isn't a K&N, tho I wouldn't mind a K&N filter..instead of stuffing the landfills with the cotton ones(or whatever they are made of)
Iwas going to get the KHCharger for my Dyna 01 low rider but a wrench talked me out of it, saying it was bulky and would put my knee out specially on the pro ones. (actually might of been just the pro version). they do look cool like seeing a carb open it's floats on ahotrod classic engine.....
I am not sure what air-cleaner cover Iwill get.. there is one but forget the name butlooks almoststock but has a cutaway in the front lower part
Bushy
Mar 30, 2018 11:48 AM
WDHGS
Mar 22, 2010 04:46 PM
utz
Jan 7, 2009 11:47 AM
demaz58
Exhaust System Topics
Sep 11, 2007 10:20 PM
brian.peterson
23
Jul 14, 2007 09:36 AM
