Current in oil vent line after starter replacement
Old Apr 12, 2014 | 07:39 PM
BSpriggs's Avatar
BSpriggs
1st Gear
Default Current in oil vent line after starter replacement
Recently did a replacement of a starter on an 03 heritage softail. Took it out for a spin and noticed spark and oil leaking. After looking into it more found almost 12 volts running thru the oil vent line (the upper of the three lines that run into the engine). This causes the plastic tube the lies under the metal expansion joint in the middle of the line to melt and then leak oil. Even more fun it sparks. Anyone got ideas on what to look for? I can tell you the current appears to be only in the vent line (not in feed or return line). Other than that bike runs great. Little stumped and any thoughts appreciated.
doc308
Shovelhead
Jun 30, 2019 07:38 PM
Essthreetee
Apr 28, 2019 12:58 PM
americanworkmule
Jan 25, 2017 07:41 PM
Mr.Solar
Ironhead
May 11, 2014 04:19 PM
plane
Jun 17, 2009 09:22 AM
