Fuel tank question
Old Apr 19, 2014 | 08:36 PM
Stageman's Avatar
Stageman
Default Fuel tank question
Hey, I have a 97 fatboy, edlebrok heads, cam, and big bore kit. My problem is, it seems like I'm only pulling fuel from my right tank only. I get about 120 miles and I got to hit the reserve. When I stop to fill up, I only pump about 2 gallons in the right and just a few drops in the left......my assumption is that it should pull off both tanks (seeing there is a crossover) and then the reserve is enough to get a few miles further. I would think I could get more than 120 miles per fill up. Any suggestions? By the way, I only run high octane no ethanol gas. This is my 1st Harley and just needing some ideas on whats up....thanks.
Old Apr 19, 2014 | 08:46 PM
08Nighttrain's Avatar
08Nighttrain
Something doesn't add up. You say you are only using about 2 gallons but you get 120 miles. That's 60 miles per gallon which is really awesomely high.???????
Old Apr 19, 2014 | 08:51 PM
Stageman's Avatar
Stageman
Yeah. Yesterday at exactly 120 miles, I sputtered and clearly it was wanting fuel. I went to reserve and 3 miles down the road I filled back up. The right tank was empty. Took aprox 2.3 or so gal to fill. Went to the left tank, and it was almost full.......
Old Apr 19, 2014 | 08:53 PM
Stageman's Avatar
Stageman
Oh, and rode about 110 miles today. Got home and looked into tanks. Right side is basically empty and left side is basically full......maybe a small bit gone.
Old Apr 19, 2014 | 09:04 PM
H3llb1lly88's Avatar
H3llb1lly88
Is there a petcock under each tank? Might wanna check if there is one hasn't got disconnected somehow.
Old Apr 19, 2014 | 09:12 PM
Stageman's Avatar
Stageman
One petcock on left tank only. Crossover tube at front of both tanks...just looked and the right tank looks almost empty. The left tank, fuel can slosh out of I shake the bike...
Old Apr 19, 2014 | 09:25 PM
H3llb1lly88
Thats strange. Because it should be pulling first from the left side. You sure the sloshing isn't the reserve? My '07 don't even have a reserve. That I'm aware of.
Old Apr 19, 2014 | 09:41 PM
Stageman's Avatar
Stageman
I have no idea. I just know that the left side is practically full...I'm gonna ride it tomorrow till it runs out. Should be very close. Idk just doesn't seem correct but it might be....
Old Apr 20, 2014 | 07:52 AM
heybaylor's Avatar
heybaylor
might want to check your tank vent system, ie "no air in = no gas out
Old Apr 20, 2014 | 08:55 AM
GadgetBandit's Avatar
GadgetBandit
Something has to be blocking the crossover tube. I would remove both caps, put a hose in the right side and kinda seal around it. Blow in the hose and see if you get bubbling on the left.
