Ignition module for deuce
Old Apr 20, 2014 | 01:12 PM
Half-Fast Deuce's Avatar
Half-Fast Deuce
Default Ignition module for deuce
My 2001 Deuce's engine light is coming in periodically. Had the dealer run a scan on it. It has the Screamin' Eagle module (32719-01), dealer says it's no longer available, so ended up ordering 32568-00C which is the stock unit. Am I going to lose any performance gains? I know the Screamin' Eagle has a 6200 rpm rev limiter, does the other one have a limiter?
Old Apr 20, 2014 | 08:40 PM
DDuess's Avatar
DDuess
That appears to be the stock ignition module that is set for 5800 rpm. Some say a stage one flash will change it to 6200. The Daytona twin tech is adjustable by the owner.
Old Apr 21, 2014 | 04:54 AM
Guest
Guest
Posts: n/a
That was an inhierent problem with those modules. Infact there was a certain date that all previous to was recalled.
Been along time but I believe that module just gave it the 6200 rev limiter. There was another one for high compression that retarded the timing 5 degrees also.
I much, much perfer the DTT ignition and would not ever have a carbed bike again with out one, they are that good.
Old Apr 21, 2014 | 05:58 AM
QC's Avatar
QC
Are you using aftermarket plug wires?
Old Apr 21, 2014 | 08:44 AM
Half-Fast Deuce
I'm running the Screamin' Eagle 10mm wires and plugs. I'm not sure what all has been done to the engine, but it has SE jugs, Mikuni carb, and stage 1 breather. Just didn't want to be doing a downgrade by using the other ignition module.
marktruckee
EVO
23
Aug 17, 2018 03:19 AM
heritageJ
May 6, 2015 10:44 PM
matto371
Sep 8, 2012 11:28 AM
00ICUR12
Jan 5, 2009 09:01 AM
virtualmike13
Oct 3, 2007 04:13 PM
