Is there a company that make aftermarket bottom clamps for the 41mm HD forks?
I hate the two bolts and id rather spend 1300 on different mods than the HD inverted forks just to get rid of the two bolts.
It wouldn't be hard to get a piece of aluminum machines into a spike or smooth cap with the center machine out big enough to fit over the bolt, then buy a couple of grub screws, drill a hole slightly smaller then the grub in the side and thread it to fit the grub screw to secure it to the bolt head. I'm sure you probably already seen how they work/made. Some one with a lathe would make one up in no time if you can't find anything
I really just want to know if the one I posted will fit.
KLF33 said the forks are the same, so what that means to me is the fork bottom caps will fit.... But I need a more definitive answer before I order it only for it not to fit. http://www.ebay.com/itm/FBI-FAT-BAGG...e01d68&vxp=mtr
Thanks ink, good idea if all else fails.
Wait man, I was talking about the Axle sizes for changing the full lowers, not for the 'cover on ebay' .
That cover I have no clue what it fits on and what not, and to be honest, even if it fits (which I doubt) it would look like s..ayet..
