The Deuce "pulling" to the left???
Old Mar 28, 2007 | 12:41 AM
SpeedsterX's Avatar
SpeedsterX
Default The Deuce "pulling" to the left???
Is that possible??
I keep riding it and for some reason it seems to be "pulling" to the left.
Really! LOL!!
I rode no handed a couple of times and it seems to be pulling to the left.
Hell, I didn't know it was possible for a two wheeled vehicle.
Anyone have any ideas or has it happened to you??
It's stock and I've done no mods.
Thanks!
Old Mar 28, 2007 | 12:53 AM
OldFenderGuy's Avatar
OldFenderGuy
Default RE: The Deuce "pulling" to the left???
Sounds like your riding position isn't completely centered over the bike, and more weight is being transferred to the left side.
Or maybe the left side of your body is heavier than your right side.
Old Mar 28, 2007 | 12:54 AM
FXSTD.AU's Avatar
FXSTD.AU
Any tyre mods?
A predisposition to one side or another would probably mean either a weight balance issue (like a phatail installation) or that the rear axle wasn't centered properly... unless your left foot is considerably larger than your right :P
Old Mar 28, 2007 | 12:55 AM
HawgFoot's Avatar
HawgFoot
It could be a number of things that can cause it.
If your still running the stock spoked frontwheel it might need the spokesto be trued up.
Your rear wheel can alsobe a very likely suspect,A rear wheel not properly aligned isone of the major causes of a bike pulling to one side or the other...
Uneven tire wear can also play a role.
Old Mar 28, 2007 | 01:29 AM
purple haze's Avatar
purple haze
you have 2 shock's under bike, has any one adjusted one or both, one could be set softer or one could be firmer. just my 2 cent's PURPLE
[IMG]local://upfiles/24725/5C21F12E27C244E498CA3750F509E7C0.jpg[/IMG]
Old Mar 28, 2007 | 02:34 AM
SpeedsterX's Avatar
SpeedsterX
Great advice so far guys!!
I will check ALL those out so far (even if I've gained any weight on just one side!! LOL!)
Didn't even think about the shocks. Thought MAYBE rear tire alignment.
Will do some checking!!
Anymore thoughts are welcome though,
THANKS AGAIN!!
Old Mar 28, 2007 | 02:54 AM
BGHFD's Avatar
BGHFD
I experienced this after the rear tire was replaced. I aligned the rear tire and presto, straight down the road with no hands (on a flat surface).
I found a website that suggested making a caliper out of a wire coat hanger to make sure both sides of the axle were the same distance from the center of the swingarm pivot bolt.
I like some of the other suggestions as well, but this is a simple place to start.
Good Luck!
Old Mar 28, 2007 | 08:37 AM
breaknbad's Avatar
breaknbad
align the rear tire to the belt, not the swingarm bolts.
Had the same problem. alignment fixed the problem.
David
Old Mar 28, 2007 | 06:18 PM
purple haze
DARN HAWGFOOT I might just give you vote for B.O.T.M. PURPLE HAZE.
[IMG]local://upfiles/24725/911237D1DD8A462CBCED36F446531969.jpg[/IMG]
Old Mar 28, 2007 | 10:35 PM
HawgFoot's Avatar
HawgFoot
Thanks for the comps Haze!,
Don't know if I'd qualify or not,Hadn't been around here very long....
Some awesome bikes around this place
