Kuryakyn Levers
Old Apr 27, 2014 | 08:22 PM
CajunIron's Avatar
CajunIron
Default Kuryakyn Levers
Just put on Kuryakyn Zombie Levers now the bike will not start unless it's in nuetral. I took them back apart and inspected it. The switch is good but the lever barely misses contacting the switch. Is this common with these levers. The only reason I want it to work is if I stall out and need to get moving in a hurry.
Old Apr 28, 2014 | 07:12 AM
dimefan's Avatar
dimefan
I have no advice on your particular install but I have had the levers on my bones for about 2 years and love them. They fit my hand great and really are a solid lever. Good choice!
Old Apr 28, 2014 | 05:37 PM
DeeRides's Avatar
DeeRides
I discovered the same thing recently. I put the Kury leather braided (no fringe!) Trigger levers on mine. I posted about it at the time and someone told me about the little 'button' thing that's on the OEM levers that makes that connection. I REALLY like these levers but have thought about going back to the stock ones.
Old Apr 28, 2014 | 05:45 PM
CajunIron's Avatar
CajunIron
After further inspection there is a visible casting line on the lever and low spot where it should contact the switch. At the advise of Kuryakyn they are defective and will be exchanged with JP Cycles.
Old May 13, 2014 | 08:39 PM
CajunIron's Avatar
CajunIron
Received the replacements today from JP Cycles. Must be a bad batch as the tab does not trigger the switch. Another return to JP.
Old May 13, 2014 | 09:24 PM
Bone Doc's Avatar
Bone Doc
CajunIron,
Between the Lindby Magnumbar and the Kuryakyn levers I would leave the bike stock or use HD parts until this bad juju passes you by.
Good luck. Sounds like you need it.
Old May 13, 2014 | 10:19 PM
CajunIron's Avatar
CajunIron
Lol if it wasn't for bad luck I'd have to luck at all.
Old May 14, 2014 | 04:41 PM
Tyree's Avatar
Tyree
Check out ironbraid.com. They have leather braided trigger levers. Work without issue on 2012 Slim.
Busterboy
Jun 28, 2019 07:17 PM
Manzanillolove
Jan 30, 2015 02:33 PM
Springerfan
Sep 12, 2010 06:00 PM
KCBULLDOG
Mar 4, 2008 04:01 PM
Miklnparker
Apr 2, 2007 11:51 AM
