speedo backlight issue - help
Old May 6, 2014 | 10:23 PM
dyolfknip's Avatar
dyolfknip
Originally Posted by Theonepr83
On my 13 slim my back light off on my speedo when the sun goes down or it gets dark the light kick on the bike has a light sensor the dealer didn't even no I did my research
Was going to say the same thing, mine comes on when I pull into the garage. OP maybe that sensor is faulty?
Old May 14, 2014 | 09:59 PM
drumer66's Avatar
drumer66
your correct... its a light sensitive speedo ... and the dealer didnt know either ...
Old May 14, 2014 | 11:19 PM
bigblock59's Avatar
bigblock59
the dealership has finally diagnosed my back light issue. They said that my custom dynamics led turn signals weren't drawing enough of a load and causing havoc with the bcm. They had to contact custom dynamics to actually figure this one out. They had set a bunch of codes. Apparently they had to replace them with a different style of led from custom dynamics that would draw voltage. Who would have thought that drawing to little of voltage would cause issues?
Old May 14, 2014 | 11:28 PM
SoCalSoftailSlim's Avatar
SoCalSoftailSlim
Hmm.
I'm gonna guess the dealer is wrong. I've been running CD LEDs on my 2013 Slim for more than a year now and no problems with the speedo backlight. It may cause you to throw codes, (basically the low voltage of the LEDs makes the ECM think a bulb is out.)
But that won't have any impact on your speedo light.
My 2013 Slim backlight also comes on when I go in a tunnel or any place dark. There is a sensor. And I bet yours is faulty and the dealer doesn't even know the sensor exist.
Old May 15, 2014 | 12:04 AM
bigblock59's Avatar
bigblock59
I thought that is a possibility except I put a new speedo in it last fall because that was their first diagnosis and still had the problem a few weeks ago. I'll find out soon enough I'm sure.
Old May 15, 2014 | 01:14 AM
SoCalSoftailSlim
Good luck!
Old Mar 20, 2015 | 03:23 PM
t-bear's Avatar
t-bear
I had this issue the end of last season.
Replaced the Speedometer and have no idea if the problem has gone away until the snow in Massachusetts goes away a bit more.
Where is this light sensor located? In the speedometer itself?
Thanks
Dan
Old Mar 20, 2015 | 07:43 PM
Goldtop Dude's Avatar
Goldtop Dude
same issue with mine----I hate that sensor----just on all the time like the old days---never an issues,,,
martin10
2018+ Softail Models
447
May 15, 2021 10:41 PM
Littleredcrate
Mar 12, 2021 11:46 AM
drumer66
Apr 29, 2014 07:02 PM
ChefE
Apr 26, 2008 11:51 AM
Timmer
Nov 9, 2006 09:42 PM
