Deuce leaking gas
Old May 9, 2014 | 03:39 PM
Niteblaster's Avatar
Niteblaster
Default Deuce leaking gas
Just filled up with gas and started it up guy across the pump points down and I'm spraying gas on the ground infront of rear tire. I shut it off rolled it away from the pump and looked it over no leaks or drips no puddle. started it back up and no leak made it about 50yards spraying fuel again. Continued home about 2 miles last I know was still leaking about 1/2 mile from home. Parked in the garage left idleing side stand down no drips or leaks. Shut it off and started it reved it put side stand up still no leaks. I do sea a breather or overflow tube that is infron of rear tire I assume that was where it was coming from. Could it be just I overfilled it? Its a 2001 fuel injected.
Old May 9, 2014 | 03:52 PM
purpledeuce's Avatar
purpledeuce
Yep, most likely put too much in. I think we've all done that a time or 2
Old May 9, 2014 | 05:29 PM
Niteblaster
Ok thanks hope you are right.
Old May 9, 2014 | 11:00 PM
purpledeuce
For future reference only fill it to just under the neck line
Old May 10, 2014 | 07:01 AM
Niteblaster
OK thanks
Spy11
Shovelhead
11
May 18, 2017 05:07 PM
jruggs73
Jun 3, 2012 03:45 AM
gtrplyr
Feb 26, 2012 06:25 AM
Superdawg
Aug 27, 2008 09:02 AM
Kikilee
Jun 18, 2007 01:53 AM
