New seat type for a Rocker
Old May 14, 2014 | 07:24 AM
maddawg57's Avatar
maddawg57
Default New seat type for a Rocker
Thinking of pulling the trigger on a 08 rocker,
The seat sits high off the rear fender ,
This is holding me back.
is there a replacement kit/seat that rest on the rear fender?
To eliminate the empty space between them? thanks
Old May 14, 2014 | 07:37 AM
24v's Avatar
24v
The rear fender is bolted to the swingarm, not the frame. This means it moves with the back tire. That is why there is a gap. You can buy a kit to convert the rear fender to frame mounted type, and a new seat as well. Heartland makes a kit I believe.
Old May 14, 2014 | 11:18 AM
Warp Factor's Avatar
Warp Factor
There are a number of aftermarket seats which pretty much eliminate the gap, such as the Danny Gray.
Or if you have an FXCWC, you can reduce that gap by substituting a FXCW seat.
Old May 14, 2014 | 03:54 PM
magna's Avatar
magna
There's a few different styles on here.
https://www.google.co.uk/search?q=al...w=1024&bih=672
Old May 14, 2014 | 04:16 PM
maddawg57's Avatar
maddawg57
Thanks for all the replies,
just the information i was looking for
Old May 14, 2014 | 07:30 PM
Rodzilla6's Avatar
Rodzilla6
All you need to do is drop the rear 1 1/2 inches and put a Danny Gray seat on it with saddle gel. This completely eliminated the gap on mine and the bike rides better. Also change the rear bump STOP to one from an 07 dovetail. Seven bucks at hd and mounts in the same holes but is thinner so you don't hit...yell if you have more questions. Rocker is an awesome bike once you make it yours...
Old May 14, 2014 | 08:11 PM
m i k e's Avatar
m i k e
the stock fxcw seat sits you back a few and sits closer as well
heres a pic of mine w/ lowering bolts
Old May 14, 2014 | 08:27 PM
Rollinburnout's Avatar
Rollinburnout
Here's a pic of mine with a seat from bitchin seats.
Old May 14, 2014 | 08:29 PM
lazyboy09's Avatar
lazyboy09
This is what happens when you add the Danny Gray seat
Attached Thumbnails New seat type for a Rocker-46066_150114278345577_2645891_n.jpg   New seat type for a Rocker-20130901_150617-2.jpg
Old May 15, 2014 | 07:24 AM
Rodzilla6's Avatar
Rodzilla6
I tried the std rocker seat also and it is better, but nowhere as good as the Danny Gray seat with gel...if you want to try a std rocker seat, I have one I only used a few times and its sitting in the garage. You can have it cheap...it's never going back on.
The Danny Gray seat from sterling seats on eBay is where some of the rocker folks get deals...Good luck.
