working on an 04 deuce and need the specs. for the belt adjustment, anyone have an owners manual.
Use the 45* meathod. Tension should be such that you can rotate the belt 45*, maybe a bit more, with your thumb and forefinger. If you can't, belt is too tight.
I believe the SM says 3/8"-5/8" deflection with 10# of tension on the belt; not absolutely sure though.
