burned thighs
Old Jun 9, 2014 | 06:16 PM
Blk and Chrome's Avatar
Blk and Chrome
Originally Posted by sioux565
Actually, the cats are in the stock mufflers. Replace those with a slip-on muffler and get some sort of fuel management. It will make a night and day difference! Ask me how I know.
I agree with this as I have exaust and a tuner without any heat shields and ride in 90-100 degree temps and never got a burn. If the bike is stock it will be real hot in these temps. If you have a narrow seat you are closer to the oilbag thats real hot and if in traffic like UK Lauren said (stop&go) like Daytona heat shields plus the above and it should be livable.
Old Jun 9, 2014 | 06:36 PM
dansax's Avatar
dansax
In order for me to come up with an educated solution i must inspect your thighs.
Old Jun 9, 2014 | 06:38 PM
dennyo's Avatar
dennyo
Old Jun 9, 2014 | 06:46 PM
kneesinthebreeze's Avatar
kneesinthebreeze
Originally Posted by dennyo
Took the words right out of my brain.
Old Jun 9, 2014 | 06:49 PM
tbonetony06's Avatar
tbonetony06
Welcome biker girl. I have an oil cooler and I had my 3 head pipes under the heat shields ceramic coated. The ceramic coating protects from the heat plus if distributes the heat evenly by time it leaves the head pipes. I have zero heat issues.
BUT, I think what does it more than anything and what you might find will work best for you is to lower your bike. I have a certain rear suspension system that allows me to lower the bike, I pretty much ride slammed with just a touch of rebound. I also had my seat reworked and that lowered me about another 1/2" too.
It puts my legs more at an angle, out and away from the bike, and that pushed my leg out further from the bike. I'm 5'10". I am sure the crotch cooler will do something, many here have tried it and said so. I am going to see if I can get one in white but to be honest that will be more for cosmetics as anything else. My bike is black and white and I had my seats redone in black and white.
Old Jun 9, 2014 | 07:00 PM
203Cree's Avatar
203Cree
What were you wearing for pants?
Old Jun 9, 2014 | 08:34 PM
Steve52's Avatar
Steve52
I have a '13 Fatboy Lo and the heat off the right side was killer. Capt. Itch Crotch Cooler and a set of Screamin Eagle slip on's (no cats).....problem solved.
Old Jun 9, 2014 | 08:53 PM
WildBill_50's Avatar
WildBill_50
Install a set of slip-ons and a good fuel management will do the trick.
I have crouch coolers installed on my bike and recently I was checking out some different Superchip maps and even with the coolers installed they got HOT! Finally found a map that worked and now it is comfortable.
Old Jun 9, 2014 | 09:30 PM
jm35ny's Avatar
jm35ny
Atleast your ***** are ok!
Old Jun 10, 2014 | 04:23 PM
Captain Itch's Avatar
Captain Itch
Sponsor
If anyone ever has a Question about any of our products Please just give us a call.. Thank you
__________________
www.Captain-Itch.com
