Ordered Veids and Rush 1.75s
Old Jun 14, 2014 | 04:46 PM
TenMidgets's Avatar
TenMidgets
Default Ordered Veids and Rush 1.75s
I ran this set up on the Ultra and it worked great. I don't want to deal with tuners or downloads right now. Just make the bike run a little richer and cooler.
Can always order 2" baffles for more rumble. Next up - replace stock air cleaner with higher flow that fits under stock Cover. Any ideas?
Old Jun 14, 2014 | 06:09 PM
WildBill_50's Avatar
WildBill_50
K&N air Filter. you can get one that fits just like the stock one does.
Old Jun 14, 2014 | 08:07 PM
sioux565's Avatar
sioux565
No offense, but do not get that filter. Yes, it is a high flow air filter, but it is trapped in the restrictive stock assembly.
The SE kit from Harley will work with the stock cover. Also, V&H makes a kit to fit under the stock cover.
I went with the DK Custom 425 air cleaner kit. It eliminated having the crankcase vents go back into the air cleaner.
Old Jun 14, 2014 | 08:14 PM
checkers's Avatar
checkers
If you install a K&N element or Stage 1 ***'y, it will run lean and hotter, then the stock A/F in combination with slip ons and XIED's. Bottom line: XIED's and slip ons will perform better and run cooler, when you add the low restriction A/F it will run hotter, increase secell pop and have a light stumble on acceleration.
Old Jun 14, 2014 | 08:48 PM
TenMidgets's Avatar
TenMidgets
Thanks hat is exactly what I did with the Ultra. Just Veids and Slip Ons (although those were 2" baffles. I had very slight deceleration burbling but no back fires. I intended to turn the Veids up to 50% from 25% but sold it before I had a chance to mess with it.
If I decide to go with a a high flow Air Filter I will get a tune or buy a tuner.
Old Jun 14, 2014 | 09:48 PM
Jaburg1's Avatar
Jaburg1
I have the SE high flow air filter, XiED, and Rush 2:1, and it runs perfectly.
Old Jun 14, 2014 | 10:18 PM
TenMidgets's Avatar
TenMidgets
Good to know. I don't care much about enhancing performance. Just enough to bypass EPA regs for engine reliability. Thankfully there is no emissions testing of any kind here.
FFChuck
Exhaust System Topics
16
Oct 25, 2018 10:21 AM
03bagger30
2014-2024 Touring Models
19
Jul 5, 2017 09:21 PM
CR3999
Milwaukee Eight (M8)
20
Oct 25, 2016 12:06 PM
Wingwheel
Feb 1, 2014 03:00 PM
ninetyzero
Dec 7, 2007 06:21 PM
