Inner Axle Spacer
Old Jun 15, 2014 | 10:45 PM
bpope's Avatar
bpope
Default Inner Axle Spacer
Hi guys. After having my night train profile 21" rim since late 2011, I've decided to finally put it on my deluxe. I bought the 3/4" bearing kit and took it to local HD shop to press them in. They got the rotor side pressed in, but called me and told me they didn't have the correct inner spacer. The kit came with two spacers of different lengths. So, my question is which spacer does it's require? The longest one measures to 4.810" long. Measuring from the top of the bearing that's already installed to the bearing seating surface on the opposite side, I am coming up with 4.870". Is the spacer still not long enough? This is going on a 2006 deluxe. Thanks for the help, trying to get this done by next weekend so I can cruise.
Old Jun 16, 2014 | 05:55 AM
CouchMaster's Avatar
CouchMaster
4.870-4.810 = .06 Sounds like you need to add a 1/16 (.0625) spacer to what you already have (the 4.810) 4.810+.0625 = 4.8725
Old Jun 16, 2014 | 06:00 AM
bpope's Avatar
bpope
OK, so they have to be the exact same length then. I would figure that this would be a stock harley length that would be available?? Not sure how this setup would require a special spacer.
Old Jun 16, 2014 | 06:03 PM
CouchMaster
If your measurements are accurate then you need to fill the gap or you might push the race out of the bearing while riding. I have more experience with tapered bearings but you add/subtract thin spacers with them all of the time during assembly.
Old Jun 16, 2014 | 10:22 PM
bpope's Avatar
bpope
I see. Thanks for the info. I called an indy today that said it would be no issue at all getting it resolved, so we will see.
Screamin beagle
Wheels/Tires
Jul 25, 2019 11:21 AM
scooper321
Wheels/Tires
Feb 23, 2018 06:03 PM
EasTexUltra12
Oct 15, 2013 01:00 PM
Jackie Paper
Jul 29, 2011 02:37 PM
jsbridgew
Jul 28, 2011 12:45 PM
