Legend Suspension Total System Failure
Old Jun 25, 2014 | 02:24 PM
KumaRide's Avatar
KumaRide
What model of Legend is it? Does it have one shock that is for damping - spring, oil and valving? After you get the problems sorted out, write a review. If possible compare it with 422's or ?
I hope you get it sorted out quickly. Let them know ALL of hdforums is watching them!!!
Old Jun 25, 2014 | 02:26 PM
07 chopper's Avatar
07 chopper
I have Legends L3 and so far so good. The fittings were changed a while back for steel instead of plastic. You should contact Lengends and update some of the parts. Also, you can ride the bike slammed. Good luck
Old Jun 25, 2014 | 03:12 PM
Freelander's Avatar
Freelander
Originally Posted by Village Idiot™
Welllllll, not everyone can rider their motorcycle with a Shotgun if it goes out...about those modifications I did...
This sounds interesting. What did you do?
Old Jun 25, 2014 | 03:17 PM
Freelander's Avatar
Freelander
Ok, so good news from Jason at Legend. He looked at the pics and said he will take care of it under warranty. He said it doesn't look like a manufacture defect but since he had told me to crank the fitting down earlier he will take care of it.
But I do have to send the unit back so I will be out of riding for a while. Depending on how long it will take them to get fixed I may be emailing one of you about a stock set of shocks to get me by in the meantime.
Old Jun 25, 2014 | 03:18 PM
Freelander's Avatar
Freelander
Good to hear. Yeah, I had actually updated all of the fittings. This was the last one that needed to be changed out.
Sending the unit back today. They are taking care of it for me which is great.
Old Jun 25, 2014 | 03:33 PM
Uncle Chester's Avatar
Uncle Chester
I'll be heading down to Palmdale tomorrow and can bring a set of stockers if you want to make a trip up there to get um. Not sure if they'll work on your duece, they came off a 08 Heritage. Just let me know.
Old Jun 25, 2014 | 04:23 PM
Warp Factor's Avatar
Warp Factor
That, plus the possibility of them failing far from home, is why I've stuck with conventional shocks so far. It's nice when people stand behind their products, but it's even nicer when they don't have a high failure rate in the first place.
Freelander's Avatar
Freelander
Thanks Uncle Chester. Unfortunately I have jury duty tomorrow. If I end up not having to go I'll let you and know and see if I can meet up.
Old Jun 25, 2014 | 08:45 PM
Village Idiot™'s Avatar
Village Idiot™
Shoved a 17x6 with 200 under the rear fender. If it goes down all the way, it rubs.
Old Jun 26, 2014 | 05:36 AM
Rodzilla6's Avatar
Rodzilla6
Originally Posted by Bluraven
This thread is one of the reasons I have 2 reservations of switching to any air ride system.
I know that JD is a standup guy and his warranty and customer service is second to none.
However warranty and customer service doesn't help me 300 miles from home on a Sunday out in the wilderness of Nebraska when I have a shock failure.
The cost of the systems is the other reservation I have.
All that being said I still haven't pulled the trigger on a set of Progressive 422 RAPs, because Shotgun Shocks still seem awful appealing.
That's why I kept it simple with progressive 422 in the rear...lowered 1.5 " in the back and never any issues...get on and ride...reasonably priced also...
