Pushrod tube O-ring change
Old Apr 4, 2007 | 01:03 AM
alaskajeff's Avatar
alaskajeff
Default Pushrod tube O-ring change
OKI have NOT been on here for ages...forgive me. I am getting my Fatboy out of hibernation and need to fix a pesky oil leak I had last summer. I've got an Evo motor in my 92 Fatboywith 45K miles on it and it's never been apart, so the pushrod tube o-rings are getting pretty brittle, and it's time to change them since they were progressively leaking more and more last summer. Is there anything I NEED to knoiw to make this job easier? As in some little trick or procedure that will save me hours of time & frustration. I take it I will have to remove the top ends to get the pushrods out. Anything else I should look at or change out while I'm in there? PLEASE any help I can get would be greatly appreciated.
Old Apr 4, 2007 | 05:18 AM
JLOCKHART29's Avatar
JLOCKHART29
Default RE: Pushrod tube O-ring change
If it were me and all you have leaking is the tubes I would just cut the old rods and install adjustable ones. Not sure if HD makes them for Evo off top of head but I know Crain and several other companys do. That way it would only be a 30 min. job unless you just want to open her up to see what it looks like.
Old Apr 4, 2007 | 07:02 PM
JLOCKHART29
Hear you go 17987-98A SE quick adjust push rods for Evo1340.
89FLHTC
EVO
11
Apr 26, 2016 06:55 AM
soniccbr
Jun 3, 2014 12:08 PM
hd97fatboy
Sep 8, 2012 10:31 AM
eviliron68
Shovelhead
May 20, 2012 11:26 AM
Hoshbosh
EVO
Apr 15, 2009 09:34 AM
