Rear tire/wheel for pre-'00 softail
Old Sep 7, 2005 | 09:29 PM
birsling's Avatar
birsling
Default Rear tire/wheel for pre-'00 softail
I have seen a lot of discussion on here about the wide tire kits, and going wider than stock. How wide (wheel width, and tire width) can you go with no modifications to the stock bobtail, swingarm, struts, etc.?
Also, to put '00-up wheels on a pre-'00 bike, what do you need to change? I realize the newer style uses sealed bearings, so new wheel bearings. Do you need to change the rotors, are there different spacers, what can you tell me?
Thanks in advance!
Old Sep 9, 2005 | 04:48 PM
birsling's Avatar
birsling
Default RE: Rear tire/wheel for pre-'00 softail
Nothing on this. Give it a bump for some fresh exposure
Old May 30, 2006 | 09:13 PM
deuce dude's Avatar
deuce dude
i'm bumping this......i need to know this for a friend.....
Old Jun 2, 2006 | 01:46 PM
95BadBoy's Avatar
95BadBoy
you can go to a 150/160 with some minor mods
Old Jun 3, 2006 | 06:11 AM
Reino's Avatar
Reino
On the bottom right of this page type in 'wide tire' in the search box and you get about 50 previous entries on the subject. Happy reading.
Old Jun 3, 2006 | 02:05 PM
deuce dude's Avatar
deuce dude
this is what i'm most interested in, my friend has a 95 softail custom and wants to use my old deuce wheels......
ORIGINAL: birsling
Thanks in advance!
Old Oct 1, 2006 | 02:37 AM
deuce dude's Avatar
deuce dude
bumping this again....anybody know this???
Old Oct 1, 2006 | 03:11 AM
chops's Avatar
chops
Pre 2000 softails use a 3/4" rear axle.
Your Deuce wheel is 1" I presume.
I don't know if you can press those 3/4" tapered bearings in a Deuce wheel that is set up and machined for 1" sealed bearings.
The first step would be measure your swingarm inner axle length, then his to see if it is somewhere close.
Old Oct 1, 2006 | 03:16 AM
deuce dude's Avatar
deuce dude
wow! thanks...thats a start at least.......thanks
ORIGINAL: chops
Old Oct 1, 2006 | 11:22 AM
mopar360's Avatar
mopar360
The Deuce wheel is a 3/4 bearing same as 2000-up Softails. I put a Deuce wheel on my 2001 Softail standard, thats how I know. I know nothing about the 1999-downs though, except there the tapered bearings and the 2000-up are the sealed type.
Butch
[IMG]local://upfiles/6543/5B053DF0B0264FF1AE06567B2E53E312.jpg[/IMG]
[IMG]local://upfiles/6543/C7CE909B61C644A385551D8A37CE47DB.jpg[/IMG]
[IMG]local://upfiles/6543/F242534BEE2048FB91374D4B37ED4022.jpg[/IMG]
