which pipes
Old Jul 13, 2014 | 07:55 PM
lemonade_07flstc's Avatar
lemonade_07flstc
I like the sound of my Big Shots Long, would give the a 5-6 on loudness. They fit the Heritage look great though, not sure on baffles for them. They are not a power setup though so if you want to keep or make more torque I would suggest a 2-1 like the Bassani's mentioned above and can put the quiet baffles in. I prefer to hear the pipes but don't want drowning loud so like mine. VH Big Radius look good also but they are loud.
Old Jul 13, 2014 | 09:05 PM
timsmcm's Avatar
timsmcm
I have a v&h pro pipe on a slim. It sounds fantastic. Just a little bit louder than stock when just cruising. But when you get on it it sounds big. You get the best of both worlds, quiet for long distance cruising. Loud when you are feeling froggy.
Old Jul 13, 2014 | 09:06 PM
timsmcm's Avatar
timsmcm
Dub post
Old Jul 14, 2014 | 04:55 AM
MikeZ's Avatar
MikeZ
Mostly good recommendations here but I would steer clear of the V&H long shots or big shots. No way these are a "1 -3" on a scale of 1- 10 with 10 being loudest.
Old Jul 14, 2014 | 06:45 AM
cocky's Avatar
cocky
Like I said earlier my v&h bss are 6-7 in loudness. Luv the look of em also. However, if I do install the quiet baffles like I am considering I will post the results.
Old Jul 14, 2014 | 07:39 AM
Jake6470's Avatar
Jake6470
6th Gear
JDM, thanks for the info, and did you have to go with a fuel management device?
Old Jul 14, 2014 | 07:46 AM
Jake6470's Avatar
Jake6470
6th Gear
I have Rush slip-on slashdowns now, and they sound good, but man are they loud when doing 65+ and going up a hill. You know that short front pipe is right below the rider, so that's where all the noise comes from. Putting the tips out back will cut down on a lot of that volume.
Old Jul 14, 2014 | 07:54 AM
oct1949's Avatar
oct1949
this might help you.. most SE pipes are barely louder louder than stock.
Old Jul 14, 2014 | 09:14 AM
Jake6470's Avatar
Jake6470
6th Gear
Hey, Oct1949, that's a good clip, and pretty much what I'm after. This forum is great for getting good information! Thanks to you and the other guys.
Old Jul 14, 2014 | 11:23 AM
Jake6470's Avatar
Jake6470
6th Gear
Sandtrap and Baloot-boy, can you just strap the Road Rage on, or will I need a larger air intake and efi device?
