which pipes
Old Jul 14, 2014 | 05:31 PM
baloot-boy's Avatar
baloot-boy
Originally Posted by Jake6470
Sandtrap and Baloot-boy, can you just strap the Road Rage on, or will I need a larger air intake and efi device?
You can get away with just the exhaust, but you won't be able to maximize its performance without an air intake and tune. Go to the Exhaust section of the forum and see and listen to different setups that forum members posted. It will help you make up your mind.
Old Jul 14, 2014 | 07:37 PM
Jake6470's Avatar
Jake6470
6th Gear
Will do - thanks
Old Jul 15, 2014 | 05:16 AM
jdm65's Avatar
jdm65
JDM, thanks for the info, and did you have to go with a fuel management device?
Was running a canned powervison map before the supertrapp. After I put the supertrapp on I went & had it dyno tuned - - money well spent!!
Old Jul 15, 2014 | 07:44 AM
Superfly3176's Avatar
Superfly3176
d&d fatcat
Old Jul 17, 2014 | 06:49 AM
cocky's Avatar
cocky
An update as promised. I purchased the v&h 21869 quiet baffles to go in my bss. Removed the set screws for the baffles and end caps. End caps were aggravating to wiggle off, but old baffles slid out with my finger. I was shocked they were that loose. Wrapped some cheap masking tape around the leading edge of the fiberglass wrap to keep it from sliding down towards the trailing end of the baffle as it got slid in. Learned this from another post. I wiped the inside of the pipes with a rag and wd40, just like cleaning the shot gun barrel, and they slid in without much fanfare. Hardest part was lining up the holes for the set screws that hold the baffles and the end caps. Way longer to do this than any other step. A little fingernail polish on the threads and good to go. Three things happened, the volume went from 6-7 to about a 5 with a much deeper tone. The sort of tinny sound has completely gone away. Most of all the deceleration blap, blap, bang has all but gone. It still there at times but only a little and at a lower volume that makes it pretty much unnoticeable. Sorry for the long post but I wanted to spell out the answers to the questions I had in case someone else runs into these issues with bss. Funnest part is I bought them through my dealer to save shipping costs and when talking to them they haven't ever installed these before and was not sure if it would cure my issues. He said everyone is looking to get louder with more blap, blap, bang. Go figure.
Old Jul 17, 2014 | 07:35 AM
ramakill's Avatar
ramakill
Just wondering if you can get the same effect as the V&H quiet baffles, by wrapping the stock baffles with fiberglass matting? I have seen it done on other posts and it seems to work, but that is only listening to sound clips of before and after. have not heard the difference 'in the flesh'.
Old Jul 17, 2014 | 01:05 PM
cocky's Avatar
cocky
I don't think wrapping the stock baffles would hurt but as far as V&H goes the original baffles are cheese grader looking that's in a slow spiral rotation. I guess this to give the spent gas a rotating effect to speed up its process out of the chamber like water gaining speed in a spiral motion out of the drain in a tub? The quiet baffles I installed has a solid blank at the head pipe end of the baffle that forces the gases around it and through the glass matt and then through cheese grader baffle and then out of the end of the pipe. I guess this solid end is what gives it some back pressure. It sure seems to help in the low-mid range torque as well, or it seems to anyway.
Old Jul 17, 2014 | 02:19 PM
FLYING_BURRITO_BROTHER's Avatar
NOT A MODERATOR
Be different....
Old Jul 17, 2014 | 03:04 PM
ogh11756's Avatar
ogh11756
I have a set of D & D Fatcat 2:1 on my 2006 Deluxe.
Sound good, not too loud, and a descent torque & HP boost.
I love them
Old Jul 17, 2014 | 03:09 PM
ogh11756's Avatar
ogh11756
I love them
