Red line shockproof tranny oil question
Old Jul 19, 2014 | 07:56 AM
JustDave13's Avatar
JustDave13
Like others have said let it sit over night and check the drain pan in the morning.
You can flush it with the factory fluid that's suppose to go in there.
Just let it drain, refill with fresh factory fluid, run the bike up to temp drain again and refill with fresh fluid.
That should clean most of the old stuff out.
Old Jul 19, 2014 | 08:41 AM
hvacgaspiping's Avatar
hvacgaspiping
What I do is put in on my lift and run the bike in 2nd gear for a couple of minutes at about 25mph. This will warm up the engine and trans quicker with that load and make draining the trans a whole lot easier.
Old Jul 19, 2014 | 09:36 AM
checkers's Avatar
checkers
Originally Posted by cobrahd1999
I am trying to change the oil and its not coming out I didn't have chance to warm the bike up and go threw the gears. So my question is can I spray brake cleaner in the hole to thin it out so I can and fresh oil since I am going in for surgery on my back on the 29th.
thanks for any help.
I assume you removed the trans drain plug and not the block plug that doesn't have fluid behind it. It's easy to do by mistake.
Old Jul 19, 2014 | 02:01 PM
cobrahd1999's Avatar
cobrahd1999
Question 99 evo
Its a 99 Evo FLSTF never ran into this issue before. I will put the drnd plug back in a wrm it up to see what happens then. Its just pissing me off lol I been riding for 40 + years this is the 1st to have a hard time to drain mainly the old bikes like to drain on there own lol..
Old Jul 20, 2014 | 05:36 PM
cobrahd1999
no problems with the tranny It was just strange it didn't start draining right off the bat.. I will start it later then see what happen's if nothing happens then I will take it apart to see what's up with the oil.
Old Jul 21, 2014 | 08:09 AM
spydyr's Avatar
spydyr
Originally Posted by JayDee5150
Shockproof is some sticky stuff. I've been running it for about 20K miles, changed it twice. It'll drain out, but I've noticed even drained, it leaves a thick coating on the gears (at lease what I can see through the filler hole).
If that's what you are referring to...seeing the reddish coating on the gears, I really don't know how to flush that stuff out. Be interested in hearing ideas from the board though.
I ran redline through for 40K miles (two tranny oil changes) then I had a speedo issue where it wasnt registering after it was hot. I ended up taking out the speed sensor in the tranny and it was covered in oil goo and metal bits. I replaced it, went with harley tranny fluid and haven't had an issue in 10K miles so far. It might have been just the sensor, but just saying.
I never had a problem with it draining, though. Yes it does come out a bit thick, but it should still come out. Maybe you got a sludgy spot on the drain hole? Maybe stick a small screwdriver or coat hanger or whatever, and twirl it around to see if there's a clog.
Old Jul 21, 2014 | 01:15 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
You're supposed to change the tranny oil every 10K miles..
Old Jul 21, 2014 | 03:47 PM
Scuba10jdl's Avatar
Scuba10jdl
Very much depends on your bike. Most of the Twinkies are spec'd at 20k for the transmission.
Old Jul 21, 2014 | 05:33 PM
Rodzilla6's Avatar
Rodzilla6
I switched off from the shockproof also...to get most of it out, i drained it first, put drain plug back in and fill with some 20/50 engine oil, run for a few minutes then pull plug and drain again, then refill with your tranny fluid.
Ride safe.
Old Jul 21, 2014 | 06:24 PM
Pitbull_Dallas
Ride safe.
What was the reason you switched back from the redline?
