Heritage Rattle
Old Apr 8, 2007 | 08:29 PM
jeffflsti's Avatar
jeffflsti
Default RE: Heritage Rattle
I have a similar noise it chirps when i get started but quiets down after a 10 minute run. It sounds like the tin.
Old Apr 8, 2007 | 11:33 PM
Mikey 1450's Avatar
Mikey 1450
Thetrim ring that retains my seal beam vibrates atone certain rpm. Always has, and I have not found a way to correct this.
Old Apr 8, 2007 | 11:39 PM
Nightrider2's Avatar
Nightrider2
There's a lot of chrome and tin on the Heritages, with a windsheild, that could modify any little sound that you might hear, but, its worth looking and listning for just to be safe. That's where mantainence comes in and checking over your bike before you ride. Ride safe.
Old Apr 8, 2007 | 11:44 PM
Nightrider2
Could you by chance put a couple of pieces of thin stick on foam around the inside of the trim ring, my passing lights on my Heritage have a 360 degree foam strip around them.
Old Apr 9, 2007 | 06:39 PM
DMSC's Avatar
DMSC
My upper fork covers (or "tins") make a rattling noise. I loosen the bolts and then retighten them while squeezing the front and rear covers together.
I have to go back and redo it every few months...[&:]
Old Apr 9, 2007 | 06:50 PM
texas tom's Avatar
texas tom
Pull the headlight off and check the wires in the headlight could be bouncing around...
billbrummett
Jul 13, 2019 07:54 AM
scanner70
Apr 3, 2015 12:10 PM
Whtwolf14
Oct 7, 2013 10:48 PM
Softail Tony
Aug 10, 2009 08:41 PM
kjmorgan
Jul 31, 2007 01:58 PM
