Stage upgrade questions
Sounded pretty good, half the price of the big stage four, and you can always build on it. Anyone have any experience with this set up?
I'll admit I dont' know as much about the 103's as the 96''ers but they are probably about the same.....
IMO you need to post your riding habbits and needs...
I'll add it took me several months of research and reading to pick my Andrews 26,,,,,
Are they the BADDEST cam available,,, "NO"... but they are really GOOD cams that give 15-25% better TQ across the Sheet on the dyno..
Mostly they give me 20% more TQ between 1800 --3000 rpms over the STOCK cam,, where I spend 85% of my riding time and they are easy to tune and easy on the Engine.....
If you want better and more Info...please explain your riding habits and needs....
You could more than likely get away with retaining the stock push-rods. The rest of your list sounds good for a strong street engine.
Plenty of the SE255 cams for sale on this & other forums, rather than buying new for the dealer.
Will also require a good tuner like Powervision or TTS. - Rob
Best way to go is V&H stage one and tuner, need more power than that wait til the warranty is up and have it professionally done with a cam/tuner/top end work.
