Rear LED's on Breakout
Old Aug 3, 2014 | 12:41 PM
Stone Cliff's Avatar
Stone Cliff
Originally Posted by 24v
What about if you install the under fender LED that Harley_Charley has, and just run it as a brake light. So off all the time, then hit the brakes and it is on?
Yeah, I am considering that. Really good alternative. Thanks for the suggestion!
Old Aug 5, 2014 | 10:11 PM
Harley_Charley's Avatar
Harley_Charley
It's pretty bright as just a tail light.......
Old Aug 6, 2014 | 07:06 AM
Killer Squirrel's Avatar
Killer Squirrel
I agree, I did the same one as HC, it's pretty damn bright all by itself. I even removed the stockers and it's plenty bright back there.
Old Aug 6, 2014 | 10:18 AM
Stone Cliff
Did you do clear, red or smoke? So, do I just cut one of the wires to eliminate the turn signal action? I just want it for brakes.
Old Aug 6, 2014 | 04:15 PM
24v's Avatar
24v
No, you have to purposely wire it for signals with a different harness. If you connect both red leads to the brake light circuit, then it will be all brake only. Harley_Charley has the smoke one.
Old Aug 6, 2014 | 06:08 PM
Rhino-1's Avatar
Rhino-1
Here is the "strobing" feature on one of the LED taillights on that site: http://www.chromeglow.com/catalog.asp?prodid=539023
Old Aug 6, 2014 | 06:57 PM
HD and VETTE's Avatar
HD and VETTE
I have LED bulbs in front and rear and also the under fender strip hooked up for all functions..... CAN YOU SEE ME NOW??
Old Aug 6, 2014 | 09:51 PM
jgos929's Avatar
jgos929
I ordered a set of the CD LEDs front and rear and they should be here tomorrow.
Old Aug 6, 2014 | 11:05 PM
bklynbob's Avatar
bklynbob
Default Rear flasher
Back-Off XP
www.signaldynamics.com
EdandGrace
2014-2024 Touring Models
27
Nov 14, 2015 10:48 PM
beachdive
Feb 10, 2014 06:17 PM
papifun
May 21, 2012 04:53 PM
Cesar London
Jun 15, 2011 03:14 PM
andyp
Sep 19, 2010 08:30 AM
