Samson 28.5 true duels crooked
Old Aug 12, 2014 | 08:06 AM
mkenkel's Avatar
mkenkel
I agree,bad installation job.
Old Aug 12, 2014 | 09:19 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Grab the left pipe from the back and yank up on it. Or you can loosen every connection on it and try to get it right until you tighten everything back up and it ends up crooked again.
Old Aug 12, 2014 | 10:01 AM
Bone Doc's Avatar
Bone Doc
Isn't that how upsweeps are made?
Old Aug 12, 2014 | 10:06 AM
Samson_tech's Avatar
Samson_tech
Former Sponsor
This is just an improper installation. I have installed our true duals so many times over the years and it can be easily corrected.
What I always do is keep everything loose especially the rear Upipe and crossover pipe and put a level across the mufflers before tightening everything down. Also it would be wise to put a torpedo level on the rear brake disc while the bike is on a lift to make sure it isn't strapped down crooked. This is what I always do to ensure they are level. It's possible the dealer didn't do this and thought they were aligned correctly.
The other part is that both of the muffler brackets have about a 1/8" bit of play that you will also be able to adjust accordingly in order to get them to line up perfectly.
Thank you,
Brian
Old Aug 12, 2014 | 09:10 PM
Ramboamt's Avatar
Ramboamt
Thank you,
Brian
Old Aug 13, 2014 | 10:25 AM
j8mke's Avatar
j8mke
or if you ever want to sell the mufflers, give me a shout!
Old Aug 21, 2014 | 07:13 PM
GodIsMyJudge's Avatar
GodIsMyJudge
Default ...
Took my bike back up to the dealer and they fixed them. they look good now.
Old Aug 21, 2014 | 08:07 PM
kneesinthebreeze's Avatar
kneesinthebreeze
Good to hear. Now you need to update your profile pic with the new Samsons.
Old Aug 21, 2014 | 10:42 PM
E8USMCRET's Avatar
E8USMCRET
All the jigs are the same, the pipes are bent identical to within a pubic hair. Someone at the shop jacked this one up for sure.
Old Aug 22, 2014 | 06:18 PM
GodIsMyJudge
Default ...
white wall on the back next season.
Attached Thumbnails Samson 28.5 true duels crooked-10615672_10202416919012460_1790780666_n.jpg
