Glad we still have some rockers around...lol.
Are you putting the same oem bearings back in? I had two wheel bearing failures on my rocker. The first at six k, the second seven k later. Switched both my wheel bearings to aftermarket timken or all *****. Not worth the risk.
It might not be you...try higher quality bearings first...
Good luck.
Good luck.
Thanks for the helpful input brotha! I've always used OEM bearings. I wouldn't be surprised if the HD bearings were such shitty quality that just simply removing the wheel and re-torquing the axle bolts would be enough to **** them up.
I've heard good things about timken bearings. I'm gonna look into them. You wouldn't happen to know what size bearings our sleds run do ya? For some reason I wanna say 25mm.
And also can someone educate me on two things.
why cranking down on the rear axle bolt just as hard doesn't cause those bearings in the rear wheel to fail?
And does timken make sealed bearings? Don't wanna have to hassle with greasing open bearings every 10,000 miles.
A little background might help here. '00 to '07 bikes ran the 21 mm wide double row sealed bearings that most consider bulletproof. I swapped mine out at 100,000 miles and they were still fine.
'08 and up, Harley went cheap (yet again,) and installed single row 15 mm wide sealed bearings that failed with frightening regularity. These are the units installed on the 25 mm axle. The early units apparently were lacking in sufficient grease and since then they still need to be swapped out several times over the life of the bike.
I doubt that your lack of a torque wrench was the cause if the failure. (Be careful with water when you wash the wheels however.)
I had an issue with the Buell where the wheel bearings failed. Turned out the bearing spacer tube had been crushed, probably due to overtightening at some stage. After that any replacement bearing would fail prematurley. To check you need to measure the distances between the bearing faces on the wheel to make sure its less than the spacer tube
I see ! I suspect the bearings that were installed by the dealership last year are these cheapo ones.
Anyone of you who have timken bearings have a link to where you purchased them?
It shouldn't really matter how much torque you put on the axle. There is an inner spacer that fits between the bearings inner races inside the hub. When the axle nut tightens it squeezes the forks, outer spacers, inner bearing races and inner spacer together. When the bearings are installed the inner spacer should be snug between the bearings, with no movement. If the inner spacer can be moved around then you will be side loading the bearings when you tighten the axle. Which will cause premature bearing failure and if bad enough, binding.
That is my guess. That the inner spacer is too short. I'm running the stock bearings with no problems. I've had the front wheel off and on many times.
