Pipes pics
Old Jan 6, 2015 | 01:39 PM
  #41
splattttttt's Avatar
splattttttt
It's a FrankenHOG LOL
Old Jan 6, 2015 | 02:16 PM
  #42
ramhunter9's Avatar
ramhunter9
Just your typical V&H pipes
Old Jan 6, 2015 | 02:58 PM
  #43
ctluba's Avatar
ctluba
Originally Posted by Bighec
Are those the baffles sticking out of the pipes?
Yes, when you remove the stock shields off the short shots it exposes the ends of the baffle inserts. With the shields on they are flush and therefore not visible. I dont leave things stock, for the most part!!
Old Jan 7, 2015 | 12:22 AM
  #44
DK Custom's Avatar
DK Custom
Platinum Sponsor
New LSR C style's 2-1 only produced 2.2 more hp and no torque over my Python III's and moved the torque curve later in the rpm range. Big dip then builds..
Wow, that sucks! If you want to gain some of that low end back, check out the TTI's.
We do a lot of Dyno testing, most of the time 2-1's will give more torque across the RPM band, especially in the low and mid range. Sounds like someone made a mistake...unless they were specifically designed for high RPM running, but even then, if done right they should have increased the max torque, and definitely the max HP more than 2.2
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
James Gargs
Mar 23, 2019 04:36 PM
Edsal
Sep 4, 2016 12:49 PM
brian6123
Nov 21, 2010 09:52 AM
snuffer
Mar 9, 2008 06:08 PM
Chatham Bob
Jun 27, 2006 03:22 PM
