Lowering question.
My understanding is the shorter tubes will give you back the travel you lost by shortening the springs. Not 100% sure on that though, might want to post in the train pic thread. A bunch of guys there have gone the shorter tube route.
The photo in my sig is mine aired out all the way. You can see it still sits at and angle, but the rear is low. If you do the 4" and raise the suspension up any good amount to acheive a decent ride, you're going to have the rear higher than the front and angled down. This will alter the steering geometry in a possibly bad way and could cause some inverse handling characteristics, like a tendency to get twitchy steering and maybe even the tendency for a tank slapper. However, I don't think the angle will be bad enough for that, you'll just have to pay attention.
I'm going from a 21" to a 23" upfront, so the extra 2" tubes I'm getting on mine will only lower it about an inch for 3" overall. Also, keep in mind the front suspension will end up being rougher and will kind of negate the Shotgun if you have it set for a nice plush ride.
I have taken two inches out with the progressives, plus -2" tubes, so 4" all up and only when I raise the shotguns to full height then bikes only at level. The front end is up one inch higher then normal as I'm running a 140/70/21 tyre, in which I'm dropping back to a dunlop 130 which will drop it back down an inch. So in reality from where it is now I could drop in another 3" and still be able to raise the rear enough to give me a bit of travel to bounce on. I will though if you go after market billet trees, a little over 4" drop will be as far as you can go or the sliders will hit the trees. You keep stock trees and you go much lower.
Here's a good view dumped and pumped. I have shaved the bump stop in half too. Going to going back to the shorter front tyre and move the indicators and take another 1/4" out of the front. Don't forget with the progressives, the shorter the spacer, the softer the preload, meaning use that bit more fork
This at full height, 1" higher then factory.
The 140/70/21 is very close to being spot on the same diameter as a 23" up front. Almost 2" larger diameter then the 90/90/21, raising the front 1"
To add to that I'm not sure if different after market sliders will have slightly different lengths allowing more or less of a drop
