Get a bump when on throttle...primary chain?
Old Oct 11, 2014 | 09:40 PM
steambc's Avatar
steambc
6th Gear
Default Get a bump when on throttle...primary chain?
2001 Sportster Custom, just bought it (my first Harley and loving it).
It runs great, but I do notice I get a bit too harsh of a thump (not audible, just the feel) when rolling on the throttle. Now obviously I need to check the primary chain play, which I'll do tomorrow, but as long as I'm addressing the issue I was wondering if anyone can tell me other possible causes for this issue.
Naturally the primary chain is the most likely cause, but just in case the issue remains I thought I'd look to you guys for some guidance as to what should be looked at next.
Naturally I'll check back in with the results tomorrow. I realize I may be annoying some on the forum by putting the cart before the horse but in the interest of saving time I wanted to have other avenues of investigation in my back pocket just in case. Sorry if I'm breaking protocol as I'm brand new here, and thanks for any suggestions.
Old Oct 12, 2014 | 04:44 PM
dwagar's Avatar
dwagar
have you checked the belt tension and rear wheel alignment?
Old Oct 12, 2014 | 04:46 PM
Iceman24's Avatar
Iceman24
Clutch could be slipping too...might want to adjust it as well.
Old Oct 13, 2014 | 08:31 AM
roundy's Avatar
roundy
I have a little bit of a "chain slack" sound, I would describe it as the same feeling you get with the free play in a shaft drive. It's not mega but you can notice it more in higher gears. I just put it down to free play/tolerances, I've done a fair few miles on my '01 and its still ok.
Old Oct 15, 2014 | 10:12 AM
steambc's Avatar
steambc
6th Gear
Hey guys, thanks for the replies. The primary chain was deflecting a quarter inch beyond specs, so I took care of that and it did improve the symptom somewhat.
I haven't checked the clutch yet... I will do so. I haven't checked rear-wheel alignment yet either. Belt tension is within specs.
I kind of figured that the free play is sort of normal for a 2001 Sportster, although this one has only 5,500 miles on it. If I'm gentle with the throttle there's no symptom... you just get that backlash thump if your a little more aggressive with the throttle. Overall shifting seems fine, although neutral to 1st gives a bit more of a clank than I'm comfortable with. Of course right now I'm learning what's normal and what things I should be concerned about.
As always, I appreciate you help.
The lark
2014-2024 Touring Models
14
Feb 25, 2019 11:07 AM
Seventy4blazer
Jun 6, 2016 09:09 AM
"Redwood"
EVO
11
May 25, 2012 08:01 AM
JustDave71
11
Jun 12, 2010 11:08 AM
Shovelin dwn da road
Shovelhead
Sep 24, 2007 01:51 PM
