Ive seen a lot of xr1200 front calipers swapped on 48s, does anyone know if the matching xr1200 rear caliper (part#42948-08) will also fit 2010 48 with the 11.5 rotor? Id like to have the calipers look matching.
I've inquired about this from a couple of folks that have XR's (or the rear swingarm) and I
do not believe it will work. Look at the XR swingarm, its huge (aluminum) compared to
the XL so the caliper mount is different.
FWIW, I like the XR caliper just cause it has the HD bar/shield on it just like the fronts....
If you find out anything different, please post.
Thanks!
