Need To Eliminate Security 07' XL50
Old Jan 15, 2015 | 08:28 PM
Bodacious MC's Avatar
Bodacious MC
Default Need To Eliminate Security 07' XL50
I want to eliminate or disable my security system on my 2007 XL50. Constant battery drain is a PITA.
Looking for simplest way to do this....or do I need to take it to a HD dealership?
Old Jan 16, 2015 | 04:38 AM
grbrown's Avatar
grbrown
The simplest and quickest solution is a battery tender! If you don't have one your problem is solved. If on the other hand your battery drains quickly then you have a more serious problem than the security system and if you remove it you will still have a problem.
Tell us more about what actually happens.
Old Jan 16, 2015 | 08:46 AM
Bodacious MC
I have a battery tender and use it during the riding season. I just don't like that if I happen not to ride for a couple of weeks and the tender was not plugged in the NEW battery may be low on charge.
I just want it gone.
Old Jan 16, 2015 | 02:04 PM
cHarley's Avatar
cHarley
You need to replace the TSSM on your bike with a TSM.
Old Jan 17, 2015 | 10:00 AM
Bodacious MC
Thanks, I'll start searching for details on how to properly go about the change out.
Old Jan 17, 2015 | 03:53 PM
HOTLAP's Avatar
HOTLAP
Maybe you have another problem because my 07 with the factory alarm can sit for a month without the tender and still start fine, I only use the tender for long term winter storage.
kpdnkfoods
Dec 31, 2013 08:49 PM
flynavy
Jan 30, 2013 05:56 PM
Morrisk64
May 16, 2009 01:20 AM
dirtdobber
Mar 25, 2009 05:49 PM
lazybee
Jun 26, 2007 06:21 PM
