Rear running light out
Old Feb 11, 2015 | 12:10 PM
Calavera Negra's Avatar
Calavera Negra
Question Rear running light out
01 sporty . Brake light, turn signals, hazards, front running lights , and headlight all working. All fuses are good. Any ideas?
Old Feb 11, 2015 | 12:22 PM
HOTLAP's Avatar
HOTLAP
I assume you have changed the bulb already? is so check the socket for corrosion and that the plate at the bottom of the socket moves up & down freely, if that's all good check the wiring under the fender for tire chaffing and corrosion in any connections. Beyond that you will need a test light and a wiring diagram to continue checking up the wire to locate the problem.
It looks like your bikes very low on the back so the tire chaffing would be my guess.
Old Feb 11, 2015 | 12:55 PM
grbrown's Avatar
grbrown
Thumbs up
Hotlap has probably nailed it! Start with the basics first. Even if the bulb looks fine try a replacement, just in case.
Old Feb 11, 2015 | 03:53 PM
John Harper's Avatar
John Harper
I had a rear bulb that was out, but it did not make the flashers go faster, so I did not notice until I changed out for smoked lenses. It was all milky color when I changed it.
John
reserve
Sep 22, 2018 06:16 PM
ryderbiker
Sep 21, 2015 04:12 PM
Chaseg08
Nov 22, 2009 04:02 PM
ChipR4cam
Jul 3, 2007 08:40 PM
PistonPuller
Feb 23, 2006 09:55 AM
