Running light help
Old Sep 18, 2015 | 03:39 PM
ryderbiker's Avatar
ryderbiker
Default Running light help
I took apart my light bar on my 2013 RG Custom for powder coating and the right running light is giving my trouble. The turn signal and brake light work, but I have to push on bulb to get the running light to come on. I had a guy tell me this was a simple fix but he didn't say anything else. It seems like something isn't making contact or seated right. I can probably figure out what it is but figured I'd ask and see if this was a common thing. Any help is appreciated.
Old Sep 18, 2015 | 03:51 PM
Tactical111's Avatar
Tactical111
Sounds like maybe a bad ground or defective bulb. Check your connector leads to the bulb to make sure no wires are cracked/broken. If it grounds to the housing and you push on it and it comes on it's probably the ground. Change the bulb first to eliminate the bulb.
Old Sep 18, 2015 | 04:29 PM
mkguitar's Avatar
mkguitar
1.) make sure the bulb isn;t mis-aligned....remove and reinstall 180ş- it should go easily- if not stop
2.) swap the bulb from the other side
3.) works when pushing on bulb?...or get a screwdriver down the side and push on the socket
4.) bulb socket...get in there and have a look, esp at ground
Mike
Old Sep 18, 2015 | 04:50 PM
SIX6ONE's Avatar
SIX6ONE
I have the same issue on my bike right now... Front right side bullet does not work as a running light. Works fine as a turn signal and hazards. I can't think of anything I did lately to alter it. I thought it could be the brake light module I installed to use the rear turn signals as running/brake lights, but that's been there for over a year.
I swapped bulbs and it has the same symptoms. I'm clueless?? Subscribed!
Old Sep 21, 2015 | 01:40 PM
ryderbiker's Avatar
ryderbiker
Thanks for the advice. I had pretty much done everything suggested prior to posting. I'm three month out if warranty so that's not an option. Thanks regardles. I'm going to pull it back apart and see if I screwed something up, otherwise I'll just get new internals for that side.
Old Sep 21, 2015 | 04:12 PM
OldPhat's Avatar
OldPhat
All 1156 & 1157 bulbs are not equal, the bottom part on some bulbs is shorter then others.
This weekend I tried install a LED 1157 bulb in the rear turn signal, it just would not catch,
as I turned it into place. I examined the old 1157 bulb to the LED 1157, the new LED
was shorter on the end that turns into the housing. Now I am looking for the correct length
1157 LED blub.
cochon
19
Oct 10, 2017 06:52 AM
scasey
Dec 21, 2011 03:28 PM
Gary86
Jun 21, 2011 05:03 AM
titus3:5
Oct 6, 2009 11:07 PM
klf33
Jun 23, 2009 10:39 AM
