Sportster Ignition Problems
Old Mar 1, 2015 | 11:54 AM
stevenking's Avatar
stevenking
Stage I
Default Sportster Ignition Problems
I have a 2000 XLC 1200 she starts fine but after I ride her for 5 minutes she dies. She still has a spark and is getting fuel. any idea's out there. Coil? Ignition Module? Ive cleaned the carb very well, cleaned the fuel tank and petcock, replaced sparkplugs.
I NEED HELP
Old Mar 1, 2015 | 12:00 PM
Airframer's Avatar
Airframer
Is there a fuel filter anywhere in the system? No kinks in fuel lines.
Old Mar 1, 2015 | 03:06 PM
John_K's Avatar
John_K
How do you know it is getting fuel? Vacuum petcock will not flow if there is a vacuum leak.
Old Mar 1, 2015 | 03:24 PM
old schooler's Avatar
old schooler
You can take the cover off your ignition module,start your bike and put a hair dryer on it and heat it up and see if the bike stops,let it cool off then see if it starts.
Old Mar 1, 2015 | 04:30 PM
mrfikser's Avatar
mrfikser
you say it has a spark...that is interesting, because the way you describe it the spark controller is going bad, which is quite common with this year bike....I say check the spark again, is the spark a strong blue spark? ....I would still take off the points cover and look in there for issues, I have seen where water has gotten in there and caused all sorts of issues, also behind the spark controller is a timing bell that sometimes comes loose or breaks, I would def. check that............also I would check the fuel line and vacuum line to the gas tank to make sure they are open and not cracked and fit tight...after that I would do a compression check with the engine cold and hot....
Old Mar 1, 2015 | 05:44 PM
John_K's Avatar
John_K
Take apart the back of the fuel petcock (with the valve closed!) and check the rubber diaphragm - if it is holed like mine is then it will have trouble keeping the carb bowl filled. Mine worked okay under light throttle but at WOT the carb will starve in no time. Also check the vacuum line going from the carb to this...
Jeff Fisher
Jul 19, 2016 12:25 PM
DragonArm
Jul 16, 2013 10:59 AM
rdb883
Sep 10, 2009 10:53 PM
Crazy Canuck
Exhaust System Topics
Apr 8, 2009 04:11 PM
Reece
Mar 21, 2006 08:55 PM
