is this right?
Old Mar 15, 2015 | 10:36 PM
Juan L's Avatar
Juan L
Moderator
Have you counted the teeth on the sprocket you put on?
Check out this thread:
http://www.chopcult.com/forum/showthread.php?t=38887
I hadn't noticed before but our charts are opposite! I think the one I posted is bad.
Old Mar 15, 2015 | 10:42 PM
solorider75's Avatar
solorider75
Yes I counted the teeth on it before installed and there is 51 plus if it was off I would've be calling the online vendor I got it from.
Old Mar 15, 2015 | 10:47 PM
solorider75
Rwhisen I noticed a lot of charts like yours and a few like mine. So that's why I was a little confused I what I was getting for info.
Juan L's Avatar
Juan L
Moderator
If you want to go faster than what you had on the 55 you're going to have to put on a 53 or 54 provided your chain is long enough.
Old Mar 15, 2015 | 11:09 PM
lewk's Avatar
lewk
Originally Posted by rwhisen
So you went from 55 to 51 which explains why you lost top end and ...
Ehh??? Are you referring to the rear sprocket?
Old Mar 15, 2015 | 11:11 PM
solorider75
That's what I figured just wasn't sure because of all the different charts I looked at. I want the better gas mileage because I drive this beast 105 miles a day to work and back so I guess time for another new sprocket and chain.
Thanks for all the input guys
Old Mar 15, 2015 | 11:14 PM
Juan L's Avatar
Juan L
Moderator
Yep, his bike doesn't have enough power to push that gearing combination. He needs to get back closer to his original ratio, maybe -1 on the rear.
Old Mar 15, 2015 | 11:16 PM
Juan L's Avatar
Juan L
Moderator
Could go +1 on the front too
Old Mar 15, 2015 | 11:18 PM
solorider75
Lewk yes I am referring to the rear sprocket. Any more input will be greatly appreciated
Old Mar 15, 2015 | 11:20 PM
Juan L's Avatar
Juan L
Moderator
Front Rear Ratio Torque Speed
23T 49T 2.13 -12.2% +12.2%
23T 50T 2.17 -10.0% +10.0%
23T 51T 2.22 -7.8% +7.8%
23T 52T 2.26 -5.8% +5.8%
23T 53T 2.30 -3.8% +3.8%
23T 54T 2.35 -1.9% +1.9%
23T 55T 2.39
23T 56T 2.43 +1.8% -1.8%
23T 57T 2.48 +3.5% -3.5%
Increase in speed is theorectical, as the engine may not have enough power to reach this speed
