Problem with neutral light?
Old Apr 24, 2007 | 11:31 AM
37sportster's Avatar
37sportster
Default Problem with neutral light?
Yesterday I was riding my 07 883 that I have had for 3 weeks and noticed the neutral light was not coming on anymore more. It would go into neutral, just no light. I was wondering if anyone else has had this problem and if I should be worried. Of course it's still under warrenty but I just wanted to know if there were more with problems? Thanks.
Old Apr 24, 2007 | 11:57 AM
Booey424's Avatar
Booey424
Default RE: Problem with neutral light?
Mine does that sometimes.I just puul up or go down slowly on the shifter till it comes on.Thats always does the trick for me
Old Apr 24, 2007 | 12:39 PM
T in San Diego's Avatar
T in San Diego
I had the same problem with my 1200 when it was new. Then it started working and all is well.
Terri
Old Apr 24, 2007 | 01:18 PM
rh8234's Avatar
rh8234
Not sure on the sportsters, but on the Dyna, the plugs connecting the wires to the neutral switch can get knocked off easily when cleaning the bike. I pinched the connectors a little tighter and reconnected them so they stay on more securely.
Old Apr 24, 2007 | 01:20 PM
RED_5's Avatar
RED_5
I had that problem this morning,I was backing my Nightster out of the garage and noticed the neutral light wasn't on. I kicked it down into first and then back up into neutral and it stayed on. I'll be keeping my eye on it to see if it happens again.
Old Apr 24, 2007 | 03:14 PM
SportyPig's Avatar
SportyPig
It quite likely is just the bulb in the indicator light. I know they made some changes there in 07, but my 06 had 3 of those little bulbs burn out within the first few hundred miles. Hasn't been a problem since then.
As I think about it, are the 07's still little bulbs, or did they upgrade that to more of an LED type light?
Old Apr 24, 2007 | 04:08 PM
RED_5's Avatar
RED_5
LED style lights.
I'll see how many more times this happens before I call the dealer. If anyone else has this problem please post.
Old Apr 24, 2007 | 11:15 PM
DaveJ's Avatar
DaveJ
ORIGINAL: rh8234
I had the same problem on my Softail. I, too, pinched the connectors a bit and haven't had the problem resurface.
Old Apr 25, 2007 | 08:03 AM
dbleagle's Avatar
dbleagle
My problem is the other way around... My light will come after some time and only go off in 1st it stays on through the rest of the gears... been doing that for about 12k miles...
I've gotten use to it... lol .... well sort of...
Charlie D.
Old Apr 25, 2007 | 09:14 AM
bigtop1's Avatar
bigtop1
The contact point for the neutral light to come on is very slim. It takes some time to get used to it. You have only had the bike for a short time. Perhaps a little more time is needed to get used to its position and feel.
