Rear lights keep burning out... Please help
Old Jun 6, 2015 | 09:58 AM
JimmyL's Avatar
JimmyL
Default Bulbs
Well, this may be irrelevant to your situation, but my rear bulbs were going out. I looked closely at them and they were melted at the tip. Apparently the previous owner had gone a little overboard with the dielectric grease and the connection was getting too hot and was melting the softer metal on the tip of the bulb.
Old Jun 6, 2015 | 10:14 AM
Bowhunter8607's Avatar
Bowhunter8607
Originally Posted by John Ha
Specifically which bulbs are the problem - the rear turn bulbs? Are the fasteners that hold the light assemblies to the chassis tight? A lot of vibration will definitely kill bulbs quickly.
They are the only 2 rear lights on my 48. They both have 2 filaments one filament for the brake lights and turn signals and the other for the tail lights. Everything is nice and tight.
Old Jun 6, 2015 | 10:16 AM
Bowhunter8607
Maybe that was my problem. I noticed a bunch of build up of dielectric grease in the sockets. I cleaned it up as best as I can. I haven't tried the new bulbs again yet but thinking im going to today and see what happens.
Old Jun 6, 2015 | 10:46 AM
OddJack's Avatar
OddJack
Happened to me twice.
The solution is simple:
Amazon.com: Custom Dynamics LED Turn Signal Inserts - Bullet/Deuce Style - Red dual function GEN-200-R-1157: Automotive Amazon.com: Custom Dynamics LED Turn Signal Inserts - Bullet/Deuce Style - Red dual function GEN-200-R-1157: Automotive
When I bought them last year I paid only $65, I am surprised they are so expensive now.
Old Jun 6, 2015 | 12:06 PM
Bowhunter8607
So are those inserts that plug into the existing sockets or a whole new set up?
Old Jun 6, 2015 | 12:19 PM
OddJack's Avatar
OddJack
Existing socket. The end of the wire looks just like the bulb's base.
This looks the same, different brand:
Old Jun 6, 2015 | 12:39 PM
Bowhunter8607
I think I'm gonna have to go that route. They seem nice and led's would last longer I would assume. Thanks for the suggestion!
Old Jun 7, 2015 | 04:11 PM
Bowhunter8607
I found the Custom Dynamics white dual function inserts on Revzilla for $69. Thats the lowest price I've found them at so far. I will be ordering some soon. Did you have to use a load equalizer for yours? It seems that it is only needed if you change the fronts to LED's as well. Just curious.
Old Jun 7, 2015 | 06:44 PM
OddJack's Avatar
OddJack
No equalizer needed if installing one pair only.
cgmartine
Electrical/Lighting/Alarm
11
Sep 28, 2016 11:21 PM
Mattster
Mar 23, 2015 08:42 PM
black00z28
Oct 20, 2010 11:34 AM
weldking888
Shovelhead
Jun 21, 2009 04:30 PM
Shovelhead77
Mar 21, 2006 07:12 PM
