Air shocks question?
Old Nov 6, 2019 | 01:10 PM
  #91
handirifle's Avatar
handirifle
I weigh 180 and wife is close. I run mine either empty when solo or 5 psi. When 2 up I run 10 psi. On real hard drops we come close to bottom so adjust yours accordingly.
Old May 12, 2020 | 03:25 PM
  #92
Packgrog's Avatar
Packgrog
OK, so I don't clog the "What did you do" thread (referencing my post https://www.hdforums.com/forum/sport...l#post19107244)...
Which the hell one of these makes sense for shock oil? All roughly the same price, but struggling to tell much of a practical difference.
Amazon Amazon
Amazon Amazon
Amazon Amazon
It's also maddening that the lowest price I can find thus far for the 5/32" hose is $13 for 32.8 ft. I need at most a fraction of that just for emptying and refilling the shocks. I'm probably going to stick with separate schrader valves longer term rather than spending even more time faffing around trying to find a proper hose and schrader T-junction setup.
Any other component recommendations?
EDIT: Alternatively, as per the video floating around for replacing the shock fluid, they recommend the Amsoil Shock Therapy, which is twice the price! Is that actually worth that premium!? Is it better to use the 10 weight (
https://www.amazon.com/Amsoil-Shock-Therapy-Medium-10-Quart/dp/B008JH8LGG/ https://www.amazon.com/Amsoil-Shock-Therapy-Medium-10-Quart/dp/B008JH8LGG/
) or 5 weight (
https://www.amazon.com/Amsoil-Shock-Therapy-Light-Quart/dp/B008LXJFNG/ https://www.amazon.com/Amsoil-Shock-Therapy-Light-Quart/dp/B008LXJFNG/
) on a Sporty?
Old May 13, 2020 | 12:36 AM
  #93
JP7's Avatar
JP7
I used 8.5 ounces of Bel Ray 10 weight shock oil in mine. I didn't have schrader valves and wanted to see how it rode right away so, I just put some 1/8" pipe plugs in to test ride it. It worked great and a year later I still haven't gotten around to getting the Schrader valves. I weigh about 250 lbs and it takes a big pothole to bottom it out. My daughter also rides this bike and weighs about 160. She says it rides so much better than the stock shocks too.
Old May 13, 2020 | 10:10 AM
  #94
hypecat's Avatar
hypecat
Where can i get the "pipe plugs"? Are they brass?
Old May 13, 2020 | 10:12 AM
  #95
JP7's Avatar
JP7
Any hardware store should have them. 1/8" NPT.
Old May 14, 2020 | 09:54 PM
  #96
Mongo40's Avatar
Mongo40
I got a simple question, where are you all finding the air shocks to swap out? Ebay??? thanks
Old May 14, 2020 | 09:59 PM
  #97
Packgrog's Avatar
Packgrog
I got mine via Facebook Marketplace
Old May 14, 2020 | 10:39 PM
  #98
handirifle's Avatar
handirifle
Ebay for mine
Old May 15, 2020 | 09:11 AM
  #99
hypecat's Avatar
hypecat
What is the best choice 12" or 13" air shocks? I'm looking at trying some out on an Iron 883.
Old May 15, 2020 | 11:04 AM
  #100
Packgrog's Avatar
Packgrog
Presumably the longer the better (more travel = better ride). I went with the 12" because my stock shocks were 11.75", and I didn't want to spend extra money on lowering blocks to keep the stock height.
DaytonaSportster
Feb 17, 2020 11:44 AM
scottylonebull
Sep 22, 2015 08:36 AM
Anthonys1200c
Apr 30, 2014 08:36 AM
Iron lHorse
May 21, 2010 05:14 PM
brinsr
Nov 16, 2009 09:42 AM
