Removing oil pressure sensor
Old Jul 23, 2015 | 02:02 PM
DavidStiebel's Avatar
DavidStiebel
Question Removing oil pressure sensor
Hey all,
Completed my 2008 1200XLC rebuild, have had 2 oil issues and now the oil sensor seems to need cleaning.
I'm looking for a simple way to remove the sensor, any routines that worked for you?
Regards,
Last edited by DavidStiebel; Jul 23, 2015 at 02:03 PM. Reason: added missing details
Old Jul 23, 2015 | 02:22 PM
cHarley's Avatar
cHarley
Best I remember, it's been a few years since I replaced mine, was that it's not in a wrench (socket) friendly location. I was able to grab it with a pair of Channellock pliers.
Old Jul 23, 2015 | 05:37 PM
lh4x4's Avatar
lh4x4
I believe in using the right tool for the job. HD makes a 12 socket with about 1/4 th off it cut out like the oil filter tool. It has a handle on it. It will only rotate a fraction of a turn. I had borrowed one from a HD tech. The reason that some of the sidewall must be cut away is that the sensor almost touches the case at the rear of the sensor.
Then I bought a 12 point socket and made my own. I used it to install an oil cooler uses the stock location of the sensor. The sensor gets moved to another location.
The tool is not needed often but when you do it makes it easy.
Old Jul 23, 2015 | 06:30 PM
cHarley's Avatar
cHarley
And some people can afford to have (is it 16 now or more?) Harley's in their garage and money is no object.
Old Jul 23, 2015 | 08:08 PM
John Harper's Avatar
John Harper
Just don't gorilla tighten the new one, I believe you can actually crack the case if you go too heavy on the wrench.
John
Old Jul 24, 2015 | 03:45 AM
DavidStiebel
at 1/8 or 1/16th turn per effort I think 12-16 IP is snug plus a bit. I have done this kinda thing before but never in such a cramped space.
Originally Posted by lh4x4
. . . Then I bought a 12 point socket and made my own. . . .
WHAT SIZE is the 12 point socket?
Anyone got a picture of the HD-48386 tool? Cant find anything, I would make one or something similar to jimmy the old one loose.
is this it?
cHarley, we all wish for better times too, enjoy the Hammering.
Old Jul 24, 2015 | 08:47 AM
John Harper
I have a "wobbly" socket for removing these kind sensors from cars. Mine says 1"- 1 1/16" on it. Maybe you can find one of those at an auto parts store? I think those sensors are NPT threads so they taper.
John
Old Jul 24, 2015 | 09:40 AM
Kenny94945's Avatar
Kenny94945
07 Nightster...I had to replace this sensor once.
+1 for the right tool.
Nothing at parts store, Home Depot, or my own tool box etc seemed to work for me.
I recall there is a picture of the right tool in the OEM factory service manual and it is an open ended wrench.
Not simple, limited access, I believe it took me over an hour.
As I recall, I removed the oil filter, the rectifier and the plastic support panel behind the rectifier. Then I used a channel lock tool to remove and install the sensor.
None the less - please have fun wrenching on your bike!
rhallman
Dec 29, 2020 12:21 AM
hythomasf
Jul 3, 2016 03:32 PM
harleyboy2
Softail Pictures
Oct 6, 2012 09:13 PM
Kenny94945
May 8, 2011 09:36 AM
kashlak
May 7, 2011 09:00 AM
