Won't start
Old Aug 15, 2015 | 03:30 PM
jamielee09's Avatar
jamielee09
Stage III
Exclamation Won't start
Hi guys.
I have a 2004 1200c sporty. last week it wasn't starting very well, tightened the batt cables, started, it shorted out due to an exposed ground wire and melted battery , replaced the battery, fixed the exposed wire and will not start, I now have power, I have fuel to the carb, have spark too.... what the heck happened? Any suggestions on what to check? All the fuses are good...supposed to be leaving thursday for a 2 week haul....
Old Aug 15, 2015 | 04:06 PM
JustOneDean's Avatar
JustOneDean
Does it crank when you hit the starter?
Old Aug 15, 2015 | 04:34 PM
jamielee09's Avatar
jamielee09
Stage III
Yes, cranks hard. Fresh batter, cables and connectors are tight and clean.
Old Aug 15, 2015 | 04:58 PM
HOTLAP's Avatar
HOTLAP
Try swaping the two black relays in the fusebox.
You sure you got all the correct wires back on the battery terminals?
You say the exposed ground wire shorted? did it short against the positive terminal of the battery?
Old Aug 15, 2015 | 05:20 PM
jamielee09's Avatar
jamielee09
Stage III
No it shorted out on the negative terminal... all wires are connected properly on the new battery. Will try the relays. Thanks
Old Aug 15, 2015 | 05:56 PM
HOTLAP's Avatar
HOTLAP
OK somethings wrong, a negative cable can't short on the negative terminal as they are both negative, it must have been a positive cable if it shorted on the negative terminal, or a negative cable attached to the positive on the battery. I think you have some mismatched wiring on the battery.
Pfarley1
Jun 24, 2018 11:37 AM
Nitro Joe
May 4, 2018 10:08 AM
Frank Gomez
Aug 7, 2013 12:11 PM
rebelrebel66
Jul 8, 2012 01:38 PM
albieback
May 15, 2012 07:21 AM
