Engine revvs up all by its self.
Old Sep 8, 2015 | 12:08 PM
Atlaska's Avatar
Atlaska
Default Engine revvs up all by its self.
When I start my bike, the engine revs up all by its self and will not rev down. As if you twisted the throttle and do not let off. I have been told that the throttle position sensor may be bad or I may have an intake leak. I know for a fact it is not the cables binding or the butterfly valve sticking open as I have already inspected both of those. The throttle itself functions just as it should. The engine just doesn't revv down, and when riding, it actually revvs up higher and higher.
This whole problem started out of nowhere so I am assuming its something loose? Is that a dumb assumption? What should I check?
I can take it to the dealer and it is under warranty but my dealer has a 12 day lead time and this is my only mode of transportation now so i'd like to check it out first and make sure its not a simple fix. I cant be down a bike for 12 days unless I absolutely have to.
Bike: 2014 Sporty 48 EFI no carb.
Old Sep 8, 2015 | 12:12 PM
Iarecobra's Avatar
Iarecobra
Need more info. What year bike. How high are the revs. Only when cold out like first thing in the AM. Or even after its warmed up.
Old Sep 8, 2015 | 12:24 PM
Atlaska's Avatar
Atlaska
Bike: 2014 Sporty 48 EFI no carb. This happens at all times when the bike is on. It does this during start up and then idles down a little bit. Then after riding it a few miles, the RPMs start to go up all by its self and only come down randomly. But then go right back up.
Old Sep 8, 2015 | 12:35 PM
Curt1953's Avatar
Curt1953
Being in Atlanta, GA. You got to have more HD dealers. That's going to end up getting you hurt or killed.
Old Sep 8, 2015 | 12:50 PM
Hey Man's Avatar
Hey Man
Have you checked for intake leaks?
Old Sep 8, 2015 | 12:57 PM
Atlaska's Avatar
Atlaska
I was told that may be the cause. How would I go about checking this?
Old Sep 8, 2015 | 01:14 PM
Guzzi's Avatar
Guzzi
Do you have a tuner with a wire that taps into the TPS harness?
Old Sep 8, 2015 | 01:47 PM
Atlaska's Avatar
Atlaska
Like a fuel pak? No tuner installed.
Old Sep 8, 2015 | 02:17 PM
Iarecobra's Avatar
Iarecobra
To check for intake leaks. When the bike is running spray some carb cleaner around the intake where it goes into each jug. If you get a change in idle then there is a leak.
Old Sep 8, 2015 | 05:41 PM
dwoodlives's Avatar
dwoodlives
My 2014 XL1200cp did exactly the same thing. I thought it might be the Throttle Position Sensor so I replaced it. Was cheap and easy to do. Didn't help.
Took it to the dealer as it was under warranty.
Since no "codes" were being generated they were initially stumped. Finally concluded it was a faulty ECM.
They replaced the ECM and it has run perfectly ever since.
