2000 Sportster light issues
Old Sep 10, 2015 | 11:09 AM
Sportsterxl00's Avatar
Sportsterxl00
Stage I
Exclamation 2000 Sportster light issues
Ok, I need help. I own a 2000 XL Sportster and I encountered a issue this morning. My rear inticator lights are out and will not work. I omed out my rear lights and they are not bad. My blinker will not even work for my front lights. However, my break light is working when i apply the brakes as well as the running light for the brakes light. I was thinking this could be a relay because my blinkers are not even working.
Old Sep 10, 2015 | 01:20 PM
Iarecobra's Avatar
Iarecobra
Default 2000 Sportster light issues
Check your fuses. And check your flasher.
Old Sep 14, 2015 | 01:00 PM
mrfikser's Avatar
mrfikser
if the lights are dark check the wiring under the rear fender, they come loose sometimes and rub through..if the relay was bad they would prolly stay on all the time...and with the rear lamps out the front lamps won't blink (they will just stay on)...
Pse
Mar 3, 2025 07:38 PM
Projectman
Aug 10, 2024 07:42 PM
WDOMAKR
Electrical/Lighting/Alarm
Feb 19, 2014 07:35 PM
machm1969
Jan 15, 2013 06:32 PM
cbdawson
Jul 28, 2012 07:26 PM
