Headlight wire removal
Old Nov 21, 2015 | 08:19 PM
georgelemos's Avatar
georgelemos
Stage II
Default Headlight wire removal
Hi guys,
I was looking hard at google about this second wire connected to the headlight assembly but couldn't find anything.
Any of you know how do i remove the top wire as below photo ? I can remove the main wire with no problem, but the second one is on the neck of the fork and I can't see where it is connected.
Old Nov 22, 2015 | 08:21 AM
HarleyScuba's Avatar
HarleyScuba
Remove the pins from the black connector and pull the wires through the hole?
Old Nov 22, 2015 | 01:17 PM
hscic's Avatar
hscic
According to the schematics the headlight assembly should have: Headlight - black, yellow, white and Position Lamp - Orange, White with a ground from the black to the position lamp. Schematics indicate Position Lamp is for HDI only. I am assuming HDI means something like Harley Davidson International. I only have three wires black ground, yellow low, and white high on my bike (US). I just bought a headlight that had a position lamp in it with two wires, but since it is not required in the US, I just taped it up.
Old Nov 22, 2015 | 01:48 PM
georgelemos
Stage II
Thanks for the answer guys, since I didn't found a way to remove it i just cut off the top wire and with an adeshive tape I just "repaired" it.
Installed with success and the headlight is working normally.
Thanks to all!
milesvdustin
Apr 22, 2013 06:41 PM
rjheff
Mar 11, 2011 08:27 PM
2007fxdc
Dec 27, 2007 03:23 PM
lylt
Nov 26, 2007 09:16 PM
stanleyc
Jul 26, 2007 02:29 PM
