Calling all dual front disk sportster owners
Old Feb 1, 2016 | 06:03 PM
AgentOrange883's Avatar
AgentOrange883
I wonder what the difference is between part number
46449-08 and 45500076?
My bike is a 14', didn't axle sizes change?
Old Feb 1, 2016 | 06:06 PM
WKNDS's Avatar
WKNDS
Forgot to add that as stated previously, the black roadster slider
is not a gloss black, its more of semi-gloss, not flat. I hit with some
steel wool, cleaned it thoroughly with some mineral spirits, let dry, then
painted it with some Black Appliance Epoxy paint. I'm pleased with
the results so far.
And since I had the forks apart, I added Ricor Intiminators (~$180) and
Amsoil 5w Shok Therapy fork oil.
hope this helps,
T.
Old Feb 1, 2016 | 06:12 PM
WKNDS's Avatar
WKNDS
#45500076 appears to be either buffed or polished (not sure).
#46449-08 is cheaper - ~$139
#45500076 is ~$175
Prices sourced at BoardtrackerHD (http://www.boardtrackerharleyonline.com)
T.
Old Feb 1, 2016 | 06:15 PM
cvaria's Avatar
cvaria
Originally Posted by WKNDS
Here's the parts I used for my OL's '13 Iron. You dont need to do everything
I did, but you'll have to come up with replacement parts if not...
593-03-M12CH Goodridge banjo bolt 30 degree
XL Roadster right hand side fork slider 46449-08 ~$139.00
XR Master Cylinder : 42941-10 (15.87mm bore DOT4 M12x1.5 banjo) ~$95.00
Master Cylinder clamp 42808-04 ~$10.00
Fork seal kit 49378-09 (I did both forks,used two kits) ~$36.00 each
41737-04 12mm bolt
41736-04 10mm bolt
EBC FA296HH pads for XR1200 calipers 2 sets ~$40.00 each
XR1200 Left Caliper: 42943-08 ~$153.00
XR1200 Right Caliper: 42944-08 ~$153.00
EBC contour rotors FSD006CBLK 2 required, ~$190 each
Goodrich black stainless brake hose (M/C to tee) 1 @ ~$32.00
Goodrich black stainless brake hoses (tee to calipers) 2 @ ~$25.00 each
Russell tee block (dont have part number)
hope this helps,
T.
did you need to adjust the spacers?
Old Feb 1, 2016 | 06:26 PM
WKNDS's Avatar
WKNDS
What spacers are you referring to? Stock wheel so no spacer changes
needed there & no need for caliper mount spacers either....
T.
Old Feb 1, 2016 | 06:58 PM
cvaria's Avatar
cvaria
T.
The spacers on the axle. I'm not sure wtf im talking about, but i was asking to be sure i didn't run into any more surprises. So, you just bolted everything up?
Old Feb 1, 2016 | 07:23 PM
WKNDS's Avatar
WKNDS
The only surprise I can think of would be if you call Arlen Ness & they dont offer a
caliper adapter for the RH side (since appears you're doing a large rotor changeout)
T.
Old Feb 1, 2016 | 09:40 PM
AgentOrange883
WKNDS-
I did some further digging, from 2013 to 2014 there was a change in axle size.
2014 Iron 883 and a 2014 Roadster use a 43000001 Axle
2013 Iron 883 and a 2013 Roadster use a 43895-08 Axle
All of the information your provided is correct for a 2013 dual disk conversion.
For a 2014-2016 Iron 883 owner, you will need the 45500076 right fork slider. It will not be an exact match in color for your left slider as it is a SEMI gloss black, not a gloss black.
I am aware that I will need the brake master cylinder and lines to make this work. However I just wanted to clarify what is needed.
I plan on ordering both left and right fork sliders off of the 2014 Roadsters. That way they match color wise and they have OEM durable paint finish.
Ill keep everyone posted on exact part numbers and any further information I come across alone the way.
Thank you everyone for your input.
Old Feb 2, 2016 | 01:56 PM
cvaria's Avatar
cvaria
T.
I called them and they said they didnt, too much braking power.
I thought about it for a minute and figured that since the calipers mounts during the pre2007 dyna time period and sportster caliper mounts have really changed. I went out to the garage and test fitted the adapter that came with the big brake kit 02-965 (was wrong for my 2013 dyna, fits 2006 and down dynas). It fit perfectly.
So i ordered 02-267 (rh kit for 2006 and down dyna). when i mount both, i will switch to the dyna adapters. Solved.
I'll be flipping over the handlebars in no time.
Old Feb 3, 2016 | 12:15 PM
cvaria's Avatar
cvaria
it looks like kit --FORK REBUILD XL- 49378-09 (https://www.surdyke.com/AdvPartInfo....umber=49378-09) only services one fork, yes?
i'm trying to pinch a pennies since i'm already in project cost overrun with another sporter rear axle overhaul and dyna twin disk conversion still waiting to be done. learning a lot through hard knocks though.
i found this but am leary of the cheapness.
http://www.ebay.com/itm/39mm-FORK-SE...tTxrp3&vxp=mtr
can anyone vouch for another quality set the will not run $30+ per fork? i'll cough it up if need be.
drag has a kit, but i have sworn them off as evil. http://www.bikebandit.com/aftermarke...d-kit?m=152031
