Bound Nut and bolt
Old Apr 6, 2016 | 02:09 PM
kewk's Avatar
kewk
6th Gear
Default Bound Nut and bolt
Hey guys,
I was installing a sissy bar on my 2009 Iron and when tightening the last rear fender strut bolt, it bound up on me, just short of being fully tight. Now I have a loose nut and bolt that I can't seem to tighten all the way down, nor can I loosen it to back out and start fresh. To make matters worse, I used loctite... Trying to figure out a way to remedy this problem without having to remove the rear tire to get heat to it. How screwed am I fellas?
Attached Thumbnails Bound Nut and bolt-2009-harley-davidson-sportster-883-iron-xl883n-black.jpg   Bound Nut and bolt-dcam0013.jpg
Old Apr 6, 2016 | 02:37 PM
QC's Avatar
QC
That being a socket head cap screw isn't helping. If you can possibly get a needle nose vise grip on the the nut, you could carefully use a drill starting with the smallest size that will fit inside the hex and going gradually bigger til the screw head pops off.
Old Apr 6, 2016 | 02:42 PM
kewk's Avatar
kewk
6th Gear
Thanks @QC! That is a good suggestion. No room to grab with needle nose. I will have a hard time getting a dremel grinding wheel in between. This is proving to be a real PITA.
Old Apr 6, 2016 | 02:45 PM
QC's Avatar
QC
If you put it on a lift; will the wheel drop enough to get something in there?
Old Apr 6, 2016 | 02:49 PM
kewk's Avatar
kewk
6th Gear
@QC not enough to get a torch or heat to it. I can barely sneak a wrench around the nut in there.
Old Apr 6, 2016 | 02:55 PM
QC's Avatar
QC
If you can get a no end wrench on it, give my suggestion a try. Just make sure you out some masking tape or protection on the surrounding chrome in case you slip.
Good luck.
Old Apr 6, 2016 | 03:04 PM
kewk's Avatar
kewk
6th Gear
@QC, Thanks Man! I will give it a shot and let you know.
Old Apr 6, 2016 | 03:07 PM
QC's Avatar
QC
Be patient and take your time. No need to rush now
Old Apr 6, 2016 | 04:56 PM
hammer6315's Avatar
hammer6315
How about disconnect the shocks and raise the bike, letting the swing arm drop?
Old Apr 6, 2016 | 07:01 PM
kewk's Avatar
kewk
6th Gear
Not sure. That was my first thought, but also will require me to call in a couple favors, as I am ill-equipped for that procedure. The more I think about this, the more I realize I will have to move the rear tire regardless, because I need to heat heat the bolt or nut to break the loctite. FML
