Electrical Challenge
Old May 16, 2007 | 09:58 AM
gpodwis's Avatar
gpodwis
5th Gear
Default Electrical Challenge
I seem to have a slow batterydischarge in my 2000 883 Sportster. If the bike sits for two weeks without running or without the trickle charger on, the battery doesn't have enough power to start the bike. Since the battery was 5 years old, I assumed it was dying so I replaced it without improvement in symptoms. Another symptom is thatthe speedometer will occasionally drop to zero when I turn on either turn signal. Signal on, speed registers zero for a moment and then returns to normal. Battery connection is tight.
Anyone else with this problem/solution. I assume there is a short. Any thoughts?
Old May 16, 2007 | 10:24 AM
jterp's Avatar
jterp
Default RE: Electrical Challenge
What year bike?
Old May 17, 2007 | 05:12 AM
iasporty's Avatar
iasporty
well has anything been done like changing out the grips or anything in the handle bars?
Old May 17, 2007 | 08:24 AM
dbleagle's Avatar
dbleagle
That's going to be a tough one...
It may not have anything to do with the turn signals itself, but since it's an indicator... I'd start there...
Maybe removing the bulbs or unplugging the turn signal harness, breaking the complete circuit and see what happens... maybe there is some type of feedback in the circuit...
Without a wiring diagram it's almost impossible to tell which circuit get their power from where... ( one circuit feeding another) and it could be almost anywhere and often times where you'd never expect...
Regardless it's going to be a process of elimination, unless you find someone who experienced the exact same problem...
Good luck...
Charlie D.
Old May 17, 2007 | 09:00 AM
cHarley's Avatar
cHarley
To start the process of elimination the easy way, remove the fuse for the lighting circuit when you park it. If that doesn't help try a different fuse the next time. You haven't added an alarm system have you? That will kill a battery after a few days.
Old May 17, 2007 | 10:47 AM
gpodwis's Avatar
gpodwis
5th Gear
I have not changed anything on the handle bars. When I asked the dealer about it, it sounded like they could spend a lot of time (my money) chasing it down. I was hoping someone would have had the same experience and tell me where to look first.
Thanks for your thoughts!
Gene
Old May 17, 2007 | 10:50 AM
gpodwis's Avatar
gpodwis
5th Gear
The fuse idea sounds full of wisdom. I like that and will see what happens. But that means I have to not ride for two weeks? I'll see about a battery tester to see if it is draining and thereby not have to wait the two weeks.
thanks!
Gene
Old May 17, 2007 | 12:16 PM
cHarley's Avatar
cHarley
ORIGINAL: gpodwis
thanks!
Gene
Do you have a DVM (digital volt meter)? What you want to be able to do is be able to measure milliamps. After shutting off the bike, remove either of the battery cables (which ever is easier). Place the milliamp meter in series between the battery and disconnected cable. The meter is polarity sensitive so if you get a negative reading, reverse the wires on the meter. If you have a short the meter will show current flow. Now you can start pulling fuses/disconnecting harness connections until the meter drops to zero. That should give you an idea where the problem is and go from there.
Edited: If you place the meter inline on the negative side of the battery you need to make sure the bike is not grounded to an alternate ground. That means rubber (tires) on the ground and an insulating material under the jiffy stand, rubber, wood etc.
Old May 17, 2007 | 12:59 PM
ryback's Avatar
ryback
[sm=exactly.gif]cHarley's method is right on. You can get a DVM for less than $100 that has a 0-2 Amp scale and will do the job. Better than paying the stealer, and you will have it to use again when needed.
Old May 17, 2007 | 02:19 PM
cHarley's Avatar
cHarley
An additional word of caution. Once the DVM is connected, DO NOT try to turn anything on, ignition, lights etc. The meter will not handle the current draw and it will blow the internal meter fuse or damage the DVM.
