I just purchased a 2016 Iron 883 just 2 months ago. Yesterday I noticed the left turn signal indicator is not lighting up. The front and rear turn signals are working correctly, but the indicator on the gauge is not lighting up at all. Right turn signal and high beam indicators work fine. Not sure what to check first.
the indicator or dash lights in the speedo housing unit are individual LED's in a single unit and burn out. It should be covered by warranty & HD will replace the whole light assembly. My neutral light went out & that's what they did. They said you can't replace the individual lights you have to replace the whole light unit if one goes out
Hi, I have exactly the same issue on my 2015 Iron, unfortunately out of warranty. Did you figure out what the issue was?
Thanks for your reply!
