1989 sportster 883/1200
Old Jun 2, 2016 | 08:58 AM
nitroturbo4u's Avatar
nitroturbo4u
Question 1989 sportster 883/1200
Aquired a nice little sportster that had been sitting for over a decade....Got it running now and notice some clutch slippage.
Should i buy the after market pressure plate w 30 % more pressure or is the upgrade to the multi spring extra plate kit available?
Thanks for any info......Also i need a heat shield for the front 1 and 3/4 drag pipe...I find plenty of rear ones but no front.....Thanks all....
Old Jun 2, 2016 | 04:12 PM
John Harper's Avatar
John Harper
I believe the 883 and 1200 diaphragm springs are the same until perhaps 2004. I have a 1991, so our clutch baskets are different, but the design is probably very similar. Hammer Performance probably can set you up if you want a stronger spring.
John
Old Jun 3, 2016 | 05:12 AM
grbrown's Avatar
grbrown
If your bike is close to stock there should be no need to install tuning parts, such as a stronger spring. Have you removed the clutch plates and cleaned and checked everything? Adjusted your clutch as per the book? Could be something very simple!
Old Jun 3, 2016 | 09:17 AM
nitroturbo4u
Yea,, did the adj .....Slips when you really get on it....
FXD_noob
Sep 21, 2017 01:09 PM
Batman3
Mar 24, 2015 08:15 AM
rich1374670x
Aug 16, 2012 03:58 PM
EricM
Jun 4, 2008 04:42 PM
brohrs
Oct 14, 2005 01:30 PM
