rear brake issue
Old Jun 3, 2016 | 10:32 PM
Scab45's Avatar
Scab45
Default rear brake issue
i have a 2015 sporty 48 with 1200 miles had the 1k service done at the dealer, since the 1k service i have replaced the exhaust and had no issues, iv had brake squeal issues since the bike was new and dealer just said to break in the pads but i could not take it anymore so i also added some brake quiet to the pads and at first it did reduce the squeal a lot but as of last week i have been getting a vibration in the entire bike when i use the rear brake, it does not always happen but i can feel it in the rear and in me butt. the best way to recreate the vibration is when i go over 25 mph and use the rear brake to slow down and the vibrations are the worst at around 10-0 mph when i perform a hard brake there is no vibration, it feels as tho the pads are hanging up on the drilled rotor has anyone experienced this? could i be possibly looking forward to replacing a warped rotor?
Old Jun 3, 2016 | 11:04 PM
tmultra's Avatar
tmultra
Bike should be under warranty. Have them look at it. Shouldn't cost you a dime.
Old Jun 4, 2016 | 01:09 AM
hscic's Avatar
hscic
If you are a wrencher, remove the pads and inspect the back plate. It's purpose is to absorb vibration and stop it from squealing. Perhaps crud got between the pad and plate or it has corrosion. Dealer may just replace the pads.
Old Jun 4, 2016 | 05:54 AM
Scab45's Avatar
Scab45
Are pads covered under warranty? Aren't they a wear and tear item? When I put the brake quiet on the pads I didn't notice any corrosion or crud but I guess it could be possible the friction side picked up some dirt
Old Jun 4, 2016 | 03:22 PM
hscic's Avatar
hscic
Yes pads are wear and tear...I believe unless it is defective. Pads are inexpensive and easy to replace. The dealer at the very least would inspect for possible cause.
The Borg
Jul 14, 2023 10:18 AM
Chuck1
Jun 23, 2017 12:36 AM
MikeBel
May 4, 2013 05:08 PM
tplunk
May 27, 2008 12:55 PM
bdavis
Apr 23, 2008 08:43 PM
